View Full Version : V8 Engines
- Belt tensioner on a 5.0?
- New F150 & F250
- I tried Sea Foam FI cleaner - WOW!
- Most Performance For The Money
- thermostats????
- Cracked head?!
- Nology Hotwires
- How much hp
- 1987 351w cold idle problems, hesitation
- Where is my AIC Valve? 5.0 1996 F150
- Dealer diagnostics exp.
- engine ticking
- 1998 F-150 ignition problems at 17K & 20K?
- Copper or platinum?
- Engine stalling out.
- EGR Valve Symptoms
- paint comming off bottom inside drivers door and rust 20k miles!!!!
- Vacuum Leaks
- coil pack
- Pulley Problem
- cheap lightning
- Got a challenge for all you ford geniuses!
- oil pan
- 94 300 oil pan
- replacing power steering pump
- Overdrive on or off?
- Thank you to all the EGR geniuses!!
- HELP! EGR - almost there!
- Fan clutch R&R
- Mysterious new spark plug part number.
- Upper Intake
- iridium plugs
- Some 6.0 Diesel Info.
- Lost and Found: Oil?
- oil pickup inside 4.6 troton pan
- EGR - I think I screwed up good this time
- Is there a trick to accessing oxygen sensor?
- Engine running too cold?
- Waterpump removal & install
- Engine in failsafe mode
- performance cam shaft in a 4.6L?
- Rough Idle
- dealer road test
- low idel
- Reliability and Extended Warranties
- Will I REALLY get more power???
- Service enging soon light
- Ignition parts recomendations
- P0401 Troubles (sorry about repetition guys!)
- P/N for grooved idler?
- Accident Horror/Miracle Stories
- What kinda Deals did everyone get?
- STAND ALONE FUEL SYSTEM for 5.4 2001
- spark plugs/PCV
- Slight pinging
- Air Force One intake
- Programmers
- i have no codes flashing and no spark
- Check engine light going on for a day then off
- fram oil filters
- Spark Plugs And Wires
- oil disappearing
- Alternator Problems
- Engine light turns comes on at restart
- OBDII and throtle position indicator problem
- Oil on top of Valve covers - 2002 5.4
- Seafoam...sieze / lockup the motor?
- MAF Sensor
- whine.....cant get an answer
- P0401 After Air Filter Change
- 95 and 02 SCREW Q's
- spark knock
- Sparkplugs.com
- Am I missing something? (Pic)
- 2001 4.6 SCrew Plug Change
- '97 triton4.6 F150 oil pan removal (maybe)
- Fuel Pressure? 302 5.0 Fi
- Airaid
- Throttle Position Sensor
- problems??
- Plastic clicking sound when turning engine off
- Engine Hesitation
- P0174 code
- What ratio roller rockers?
- Engine dieing in gear
- Truck has hesitation under accelleration
- ok, who knows about side mirrors, question..
- Where do the Vacuum Lines come out of the firewall?
- bad missfire at all times
- 5.4L PI Casting Number all the same? Expert help needed!
- v6 or v8
- odb2 171 and 174
- Cobra R Water Pump
- Thought I had a bad Idler pulley
- Denso Spark Plugs?
- code 1401
- CarFax Help Oasis?
- 302 eng. turns but no start
- Rough Idle
- Coil Issues.
- Engine Noises
- Errors while check engine light off?
- 4.2 to 4.6
- F350 running very rough please help
- Let you know about mileage after 0171,0174 solved
- Bingo! Throtlle, Steve and all you guys
- synthetic motor oil
- New engine
- Truck dies when driving
- Synthetic
- Hard on the engine?
- How many RPM's? 4.6L
- engine swap
- 5.4 Triton O2 Sensor
- 1986 F250 Diesel, info needed
- O2 sensors bad, should I replace or clean injectors
- Got codes: p0171=bank#1, p0174=bank#2
- 2002and2003 5.4
- 03 Expo 5.4L rough idle intermittent
- Collapsed PCV Elbows
- Engine nearly dies when stopping
- Are the Cheby's really that bad ? Man they are giving these things away
- engine ground from batt. sparking
- Sea Foam uses and suggestions
- piston size
- Save your receipts boys and girls
- whats the best plugs and wires? 4.6L
- Bad pcv, how to tell
- Turn off computer reporting
- 2004 Lariat 5.4 3v Rev Limiter?
- 4.2l V6 with 38,000 miles bad rod
- EGR Valve and Solenoid
- Failed smog.. and the codes are.....
- Poor engine performance
- 4.9 shredding belts
- Check Engine light is on code P1451 5.4 F-150
- '98 F150 4.2 Intermittent Misfire
- Loud rattle at startup
- plug/wire question
- PCM and EGR Valve????
- Noise in Engine, dealer won't tell you! Ford Knows why!
- Check engine! what to look for
- F150 no crank no start
- PO125 OBD2 code
- 5.0 Power
- truck died while driving today
- Oil filter relocation kit...thread size?
- Are my sensors bad?
- 302 Trouble code
- Code P0141
- 2000 4.6 cutting out
- check engine light - on again, off again
- Engine swap question
- funny cool down sound
- 98 f150 spark plugs and wires
- Wife's Taurus won't start after warming up
- Heater Hose Replacement
- A/C Compressor coming on with heater?
- Door Ajar sporadically kicks on while driving
- 5.4 missing at idel
- XLT & Styleside whats the diff ???
- Draining oil
- " Rattle " snake of an engine, Help.
- Seafoam in Canada
- Rough idle and loping
- Howl from engine compartment
- Spark plug and wire help 97 4.6L F-150 Vin 6
- okay, how do you get the filter off?
- gas mileage
- Gas milage and air intake???
- Starter dead, sparks flying, help please!
- Is a larger radiator possible?
- where can I get a 7 pin round trailer wire plug for my 2003 Screw
- Noise when engine off and cooling down
- need help!
- ACTUAL Gas Mileage
- Does Ford even care? PLEASE READ!!
- 1993 F-150 Almost Dead!
- Oil for the f 150 help
- 91 F150- IAC, EGR, Junk??
- Re:
- Fan clutch nut removal
- 5.4 coolant temp sensor-where?
- Questions for Factory Tech
- bad EGR valve
- Another IAC question
- whats my aprox hp?
- what size motor is the 4.6l V8?
- 4.6L Windsor/Romeo
- New 2002 F-150 owner !!!!!! opinions?
- Anybody work at an SVT dealership
- what do i need to pull a chevy?
- blue and red vacuum lines
- Seeing if I have PI Heads
- Rubbing Noise from Steering Wheel
- Plug wire, injector, coil?
- Headers on a '83 f150 4.9
- 79F250 300 6 cyl. to 351m engine swap
- 4.6l engine removal
- '93 302 w/problems
- 5.4 Plug Boot Removal Trick
- New 5.4 coil resistance sub-par.
- running fine.but ticking sound
- rear end hum
- Poor fuel economy...?
- 5.4 Dohc
- Air intake problems
- spark plugs
- two problems "engine service soon" and blinking light
- backfire? and now it has a mis>
- intake noises and rattles
- Creamy stuff on oil cap
- hesitation,miss,studder
- Who Makes Walmart Super Tech Full Syn Oil
- Any one know of a place that can do Motorswaps In San Diego
- 2000 F-150 Fuel Filter Replacement
- Low oil presure
- Spewing Gas out of filler cap
- throttle body spacer
- Engine missing and running rough under hard accel.
- Fuel Filter Replacement Problems
- anyone have crane 2030 cam and SD?
- my new truck has oil consumption probs?? help
- p0171 Lean on Bank one
- stuck spark plug
- i6 to v8?
- P0307 Code Problems?
- Piston Slap 5.4
- 300,000 mile to 400,000 mile questions
- overdrive?
- Electric Colling Fan
- misfire on cylinder three code p0303
- Remote Filter Oil Leak
- 92 F150 Ecm
- Air Induction Systems
- 2001 5.4L F150 Super Crew with a bad miss
- Oil on spark plug?
- Skip or Miss
- starting somewhere on engine mods
- Do it yourself electric fans???
- Insufficient flow related to misfire?
- need some ideas,Please
- Rich Codes.......P0174 and p0175
- Easy question Need help quick
- gas cap (sucking noises)
- clunking tranny in a 5.4
- Engine Swap help!
- Anyone know this code?
- Lighnting Blower on 2000 5.4
