HP estimation
Old Dec 20, 2000 | 11:11 AM
Casper II's Avatar
Question HP estimation
I was wondering: I have the K@N filter, modified exhaust with FM40, and the Superchip. Each proclaim some amount of HP and torque gain. I know that mods ARE NOT additive when it comes to figuring HP/torque and using a dyno is probably as close as someone can get to the actual ranges. But in generalities and for conversational purposes, what would be a good estimate of HP after the above mods have been done to the 260 hp 5.4?
2000 Flareside SC 4x4, 5.4 w/3:55, captains w/upgraded Lariat pkg and expy console, towing pkg, all power including rear window, Oxford w/gray leather,K&N, custom exhaust with Flowmaster 40. Superchip and Hellwig bars are here.
Old Dec 20, 2000 | 04:08 PM
Neal's Avatar
Cool
HI!... CASPERII : I would estimate that you have about 290-300H.P at the flywheel. It matters on exactly what mods you have done. Is your K&N a drop in filter or a FIPK? Are you running true duel exhaust or just a cat-back with a single muffler?
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Dec 20, 2000 | 04:18 PM
Casper II's Avatar
Post
Neal, Thanks for the reply. I only have the drop in filter and single in/dual out FM 40 with 2 1/2" pipes out the back, finished with 3" x 24" Tennessee Tips. I would like to think I have that much HP but would also like to hear from others with thier opinions. For big, heavy trucks, these things run like "scalded dogs"!
Old Dec 20, 2000 | 08:32 PM
Ford4ever's Avatar
Post
I would guestimate that you are getting about 280hp out of the engine, and that number will decrease as the engine ages.
Old Dec 20, 2000 | 09:22 PM
Neal's Avatar
Cool
HI!... CASPERII : Now that I know exactly what your set-up is, it's easier to figure out a estimated H.P for you. The SUPERCHIP is good for 28H.P and 46FT/LBS of torque. There are those here on this board that will say it is a lot less than 28H.P, but none of them have come up with HARD proof yet. I knocked off 6.3 tenths in the 1/4 mile with my SUPERCHIP alone. That's enough proof for me! The drop-in K&N filter is only going to be good for about 2-3H.P. A K&N FIPK or AIRAID kit will gain you 14H.P on a 5.4, proven on a"EDDY" current dyno. (extremely accurate dyno machine)I would suggest to you to look into one of these filter kits. Your cat-back, I guess is worth about 7-10H.P at the most. True duels would of been a better choice for you in the H.P department. Some will say that true duels will cost you low-end torque, but if you do your research and use MANDREL bends, you will actually gain low-end torque like I did. I proved this by my 60FT times at the dragstrip compared to when I had my stock exhaust. I could also feel it in my "BUTT-DYNOMETER"!LOL! I would NOW estimate that your H.P is somewhere around 295H.P and about the same for torque.
P.S : I would also look into a set of ASP power pulleys as well. They are pretty cheap for the H.P that you get in return. Ask MIKE TROYER about your estimated H.P gains with the mods you have and the ones you plan on later. He gets all the EXACT H.P #'s from SUPERCHIP's "EDDY" current dyno testing on their chip and aftermarket products. NEAL
[This message has been edited by Neal (edited 12-20-2000).]
