5.4 vs lightning engine
Old Nov 19, 2000 | 04:27 PM
zoso's Avatar
Post 5.4 vs lightning engine
OK, so I'm new here. It looks like the lightning is running about 100 hp more than the normal 5.4. Wouldn't an intake, chip, headers and an exhaust run you fairly close to lightning power? Not that I still wouldn't want the lightning, but I'm sure my insurance wouldn't.
Old Nov 19, 2000 | 05:51 PM
RedShift's Avatar
Talking
Zoso, you left out the most important part....The blower! BTW most insurance companies (so far) treat the Lightning like a regular F150.
Red '00 Lightning
#1388/4966
14.020 @ 97.97 mph B4 mods
K&N
Mobil 1
[This message has been edited by RedShift (edited 11-19-2000).]
Old Nov 19, 2000 | 06:24 PM
max mitchell's Avatar
Cool
Welcome zoso !! Those mods will not put you anywhere near the L. There are several good aftermarket superchargers available for the reg 5.4 . You will not get the forged pistons, trans upgrade, etc. Good Luck !!
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
Mobil 1, K&N oil filter, K&N F.I.P.K., Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s.
Old Nov 19, 2000 | 06:34 PM
Neal's Avatar
Cool
HI!... ZOSO : As you can see from my SIG, I am running pretty close to a STOCK LIGHTNING's H.P and TORQUE #'s. My best time at the dragstrip so far has been 14.53. That time was with a lot of tire spin from the holeshot and because of my stock 19lb injectors, I'm running out of fuel BIGTIME on the top end. I figure that with a set of M/T SPORTSMAN PRO's, my new SUPERCHIP's FLIPCHIP, 24LB INJECTORS, BBK 75MM TB and a PRO-M, that my truck will go 13.8-13.9 in the 1/4 NATURALLY ASPERATED! The way I look at it, anyone can go to a FORD dealer and buy a LIGHTNING. To me, it's more fun to build it yourself. It's even more fun when you beat a STOCK LIGHTNING in a street race, and when he asks to look under your hood, and see's NO SUPERCHARGER and NO N.O.S!!!!lol!
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 345H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
