Detonation Follow-up
Old Nov 30, 2000 | 11:23 PM
Ladder29's Avatar
Angry Detonation Follow-up
Well the dealer had my truck for the past 5 days and said it doesn't ping anymore. I asked what he did and he told me he reprogrammed the fuel parameters to 8.7 and cleaned the EGR valve and checked the hoses.
I drove home...No Pinging .. Out of curiosity I checked to see if the Fuel Bar was in place...GONE... I asked the dealer where it was and he said they must of forgot to put it back on. I told them to put it back on. On the way home the PINGING was back!
It's time to have a serious talk with the service guys and get the Rep involved. Will keep you posted.
98 F-250 LD E.C. 4x4,4.6 litre,K&N filter,tow pkg.,3.73rear,off-road pkg.,LT265/75R16
Old Dec 1, 2000 | 06:59 AM
black f150 offroad's Avatar
Post
so why are u so worried about the shorting bar being removed, the 99's and later dont even have them. All it does is drop timing a couple of degrees, it does not effect advance or anything like that ( its not a spout connector ), its actully quite common to remove the bar, otherwise u can go into the pcm and reprogram the octane adjust internally with a ngs, by the way the oil imprgnated filter can effect your fuel trims if u over oil
Old Dec 1, 2000 | 10:12 AM
Ladder29's Avatar
Post
Black,
Doesn't removing the fuel bar affect your power and fuel milage? Doesn't it remove the PCM's ability to control ignition timing functions?
Old Dec 2, 2000 | 05:44 PM
Post
Did your service department reprogramm the pcm, there is a tsb on this concern wich calls for a pcm reprograming, 97-98 cant remember it may only cover 5.4 though, but the wds only takes about 10 min to reprogramm the pcm if there is an updated calibration
Old Dec 2, 2000 | 06:11 PM
Post
o by the way ladder29 i dont know what he was talking about the 8.7, when u reprogram it does it automatically , if he was talking about the fuel trim was at 8.7% after reprogramming that is a bit high, he should chek maf voltage
Old Dec 2, 2000 | 11:55 PM
Ladder29's Avatar
Post
I called the service manager today (12/2) but he was off . The person I talked to said the manager talked to Ford yesterday about my situation. He didn't know what they said but the manager will call me Monday to give me a full report. I will keep you posted of the outcome. Thanks for the input / advice from all of you.
Old Dec 3, 2000 | 12:12 AM
46red's Avatar
Post
Thank you to all who have keep this topic open. I have the same problem with pinging etc. The dealers answer was only to remove the shorting bar and send me home. The pinging is less now but I wish it was gone for good. Power seems to be down a little also. Lets keep this thread alive untill someone, Ford, has a solution.
Old Dec 5, 2000 | 03:06 PM
46red's Avatar
Angry
reply to black150, no the dealer did no reprogramming, he just took off the bar and sent me home, this was their only solution.
Old Dec 6, 2000 | 05:41 PM
Post
ok what i do is clean the maf, run combution chamber cleaner throught the engine and somtime remove the octane bar (97-98 equipped only), ford has combustion chamber clean that u suck throught the intake, used to use it a lot on probes, the reason i sometimes remove the bar is depending on wheter the vehicle is city driven , if so more carbon built up as it gennerally never gets fully warmed up and that the concern may reoccure and if it does ford will take what i was payed to fix it in the first place away so basically i am covering my butt
