What is "Rod Knock"?
Old Nov 25, 2000 | 10:38 PM
Ladder29's Avatar
Question What is "Rod Knock"?
Can anyone tell me what "rod knock" is? How can I tell if my truck has this problem? Would you hear this constantly or if your putting your engine under a load
( Hills,towing )? Could this be mistaken for detonation?
98 F-250 LD E.C. 4x4,4.6 litre,K&N filter,tow pkg.,3.73rear,off-road pkg.,LT265/75R16
Old Nov 25, 2000 | 11:32 PM
Y2K 7700 4x4's Avatar
Cool
Rod knock occurs when the bearing in the big end wears out and you can hear the piston direction change via the resultant slop within the connecting rod-to-crank clearance.
It is a somewhat constant knaknaknaknaknaknaknakna that changes speed with engine rpm -- both up and down in speed.
Spark knock -- often described as 'marbles in a can' or 'ball bearings dropped in the (porcelean) bathtub' does NOT make noise upon deceleration -- only at (mostly part-throttle) acceleration.
You can often hear loose lower-end (rods -- many if not all of them) making a bdrdrdrdrdraaaaak upon cold-start on 10-yr-old GM V-6 engines -- which are oil-starved for the first one second upon start-up.
Rod knock is rare -- spark knock (aka pre-ignition) is not -- and is often reported as a symptom of oily mass-air-flow sensors (like where generously-oiled K&N filters are in use).
Does this help?
Y2K™ Jim - N8JG@Hotmail.com
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
Old Nov 27, 2000 | 10:04 PM
Ladder29's Avatar
Post
Y2K,
Thanks for the info. I don't think I have rod knock.... probably detonation..Thanks!
