??'s for those with FQR engines or heads.
Well, I took my truck (24K miles) in today due to the leaking oil problem. The service guy was pretty nice and acknowledged about the head/casting problems. Bad news is, he told me the heads would need to be replaced. I told him I wanted BRAND NEW heads. He then replied he couldn't guarantee it, because Ford only uses FQR heads as warranty work.
Is this true? That's B.S. Has anyone else been told this? I know there's very few who've gotten brand new engines. And those with the FQR heads, any problems? Thanks.
Bill
1999 F250 LD S/C XLT 4x4
5.4L, 3.73, 4R100 trans.
Flowmaster 40 "DF" series, K&N, Superchip, WMS Velocity Tube, Rancho RSX shocks, Hellwig rear swaybar, Stull billet grille, 2-PIAA Pro80XT's (120W), 2-KC Daylighters (150W), Clear Side Lens Mod w/ 9006 (55W bulbs). 265/70 R17 BFG AT KO's on 17x8 American Racing Atlas rims
Kenwood 7007 CD, Alpine 3342 Signal Processor, Alpine MRV-F353 5Ch. Amp, Pioneer TS-A6865 3-way speakers, MTX Thunderforms. CompuStar alarm/autostart. On the way: Performance Accessories 3" body lift, 33/12.5/17 ProComps, GSP grille guard and more KC's
Bill
A friend of mine at work, had his v6 engine replaced for some reason. At first, Ford sent out what looked like a rebuilt engine. Dean, the person whom I'm referring to, told them to take it back, and to send a new engine. Ford did send a new engine, after some heated discussion(sp)? If you want, I'll speak with him in the morning, and find out how he exactly acheived this.
• 2000 F-150 XLT
• 5.4 LITER TRITON V8
• 4X4 OFF ROAD PACKAGE
• SHORT BED EXTENDED CAB
• BRIGHT RED CLEARCOAT
• DARK GRAPHITE GRAY INTERIOR
• 4-SPEED AUTOMATIC W / MANUAL 4X4 SHIFTER
• 3" PERFORMANCE ACCESSORIES BODY LIFT
• 33X12.50X16.50 BFGOODRICH ALL-TERRIAN KO'S
• AMERICAN RACING BAJA'S 16.50X9.75 RIMS
• FORD SOFT TONNEAU COVER
• BLACK POWDER COATED STERLING EQUIPMENT NERF BARS
• BLACK POWDER COATED STERLING EQUIPMENT BRUSH GUARD
• TWO BLACK 150WATT DAYLIGHTER'S BY KC HILITES - TOTAL 770,000 CANDLEPOWER
• IMAGE #1 • IMAGE#2 • IMAGE#3 •
• 2000 F-150 XLT
Well the service guy is nuts if he figures u have to pull the engine to get the heads or head off. Gennerally only the pass side head leaks so u only change the pass side head gasket, and when the head is off u chek the block and the head for flatness, if the block is bad u replace the engine, if the head replace the head, niether replace the gasket. How can the guy say u need new heads without having it appart? And the biggest thing with doing heads on those engines is that the surfaces have to be spotless to prevent leaks and no have to be cleaned carefully, o by the way my pass head gasket leaked from day one, notice oil smell at about 5,000k and it was the first 5.4 in our shop that had the head done for that purpose and all that was replaced was the head gasket, but it was spotlessly cleaned and now i have 35,000k and no leak, 99 bought in oct 98 and in about jan did the head gasket. By the way i have seen a lot of post where people have had the engines replaced for head gasket leaks, and i cant see how it can be that necessary
by the way the head gasket plus related items like head bolts and other gaskets, but thats it and i have done many more the same way, i work for ford so i have seen a fair share. O by the way i have the piston slap and ford will not get me a new engine and i work for them so i will keep my old engine before i will put in an fqr, becuse if i rebuilt my engine i will use forged pistons not hyperutectic the only engine that uses forged is the lightning - no piston slap - huh wonder why - they are a windsor 5.4 too
