charging problem
Old Mar 2, 2002 | 03:28 AM
bvbsktbll's Avatar
Question charging problem
This problem just started up a few weeks ago. When I rev the motor up around 3500rpm I start to lose a lot of electric, the lights will get very dim, fan slows..etc...the higher the rpm the less power it makes. The battery indicator comes on, and of course the dummy guage does nothing. Has anyone else had this problem and if so what was the problem?? Alternator?? Belt slipping?? - Thanks
Old Mar 2, 2002 | 07:33 AM
WB9PRG's Avatar
I would check the battery connections, and the belt to start with.
If those are ok , then I would probably test the alternator.
Also, I change the battery every 5 years.
Good luck,
Gene
Old Mar 2, 2002 | 03:47 PM
bvbsktbll's Avatar
Thank You
Old Mar 2, 2002 | 04:47 PM
FamilyRide's Avatar
If it's doing it when you increase RPM's, I'd suspect the belt slipping or worse case, the alternator. I'd check the belt tension first.....
Old Mar 3, 2002 | 03:38 AM
Mach1's Avatar
Put a volt meter on it, and load the electrical system and then rev the engine and see what the voltage does...if it decreases sounds like a slipping belt...If it sqeals it probably is the belt slipping..
Old Mar 3, 2002 | 09:47 PM
bvbsktbll's Avatar
thanks
Thanks for the information, I'll try that out later today
