Fuel Pump, Need Help
Old Mar 3, 2002 | 02:05 PM
alpike's Avatar
Question Fuel Pump, Need Help
My truck has been acting weird for the last week or so. It struggles to crank when I turn the key. It will turn over for a split second and then die. I have to give it gas as if it was a carbeurated engine to get it started. The truck is a 99 5.4 ORP with 60,000 miles. Could it be the fuel pump or the fuel pump relay? Any advice would help. Thanks.
Old Mar 4, 2002 | 03:52 AM
Mach1's Avatar
Basics first, have you changed the fuel filter????A dirty IAC valve may prevent it from idling..Air filter is good???
Old Mar 4, 2002 | 09:10 AM
Y2kXLTSport's Avatar
Struggling to crank sounds like a bad battery.
Old Mar 4, 2002 | 10:13 PM
alpike's Avatar
fuel loss
I changed the fuel filter a few weeks ago and the air filter about 2 months ago. Perhaps, I should reset the computer. The problem has only happened three or four times and it always cranks eventually. Since I just changed the fuel filter it could be air in the line, but it happened 2 months before the new one. So I don't know what it could be. I am going to run some seafoam through the motor this weekend and maybe that will help. The truck also has a rough idle and a constant marble in a can rolling around on acceleration. Thanks for the reply. Any more advice?
