Service Engine Light
Old Mar 1, 2002 | 09:25 PM
Tx187's Avatar
I have a new 2001 Screw 4x4 with the 5.4 liter. today I took off the air box and tubing to look around. I unplugged the air sensor or air temp. sensor that plugs into the side of the tube. well I forgot to snap it back together and my SERVICE ENGINE light came on. anyone know how to reset the light. any help would be appreciated.
thanks in advance.
Old Mar 1, 2002 | 09:31 PM
LE PEW's Avatar
Lightbulb
Try this, disconnect your NEGATIVE side battery terminal.
Turn on your headlight switch for ten minutes.
Turn off your headlight switch after minutes.
Reconnect your NEGATIVE side battery terminal.
That should get it done for ya. Good luck.
Old Mar 1, 2002 | 09:54 PM
Tx187's Avatar
thanks alot.
