Which Is Stronger??
Old Feb 8, 2002 | 03:07 PM
WLF's Avatar
WLF
Which Is Stronger??
Can anyone tell me if the Cobra shortblock is stronger then the Windsor 4.6 shortblock. I am ready to start building a replacement motor and can't afford a race built shortblock. I can get a Cobra short block for a pritty good price and I know everything will bold up since they have the 8 bolt crank. Also I think this may up the compression some.
I can't seem to find out anywhere else so I'll check with the experts here...
Old Feb 9, 2002 | 12:15 AM
WLF's Avatar
WLF
Back to the top.... someone has to know this one...
Old Feb 9, 2002 | 10:11 AM
black f150 offroad's Avatar
first the windsor is stonger than the romeo(2v) (wich is probably why u said windsor)
-Cobra aluminumn block, windsor cast iron
-the cobra has 6 bolt mains (4 up and 2 cross bolted) - windsor is 4 bolt
-both forged crank
-i think (only think) the rods are stonger on the cobra
-both have crappy hyperutecic pisions (good idea to replace)
-cobra block stock rpm redline is much higher than a normal 4.6, again replace pistions with forged
-both full float pistion pins
depending on what you plan to use it for, i would probably still use the cobra block - just my opinion
when the cobra and 4.6 mustang came out 5.0 had an issue on the differences - between those two the cobra was far superior (but that was also a romeo 4.6 2v)
You might have better luck posting this question on corral
Old Feb 9, 2002 | 11:46 AM
WLF's Avatar
WLF
Thanks black f150 offroad,
I'm pritty sure the 4.6 in my truck had the cast crank. Rpm's is what I want. A little wt saving with the aluminum block would also be nice.
I found a couple of articles on the hyperutecic pistons and most say they are fine for N/A engines and for low boost. It seems that detonation tears them up. I plan to S/C in the future so they may have to go... It will take some time to put this togeather but I can afford to get started on a long block now...
