Maintenance Advice Needed
Old Aug 2, 2007 | 04:41 PM
blown240's Avatar
I just got a 00 F150 7700 2wd automatic 5.4 that has 155,000 miles. I have no maintenance records for the truck so I want to go thru it and make sure all the maintenance is done. I already changed the oil, and cleaned the K&N air filter, but thats it. Also, it appears that it has the original drive belt, and original diff fluid.
So far the to do list is:
Fuel Filter
Spark Plugs
Drive Belt
Diff fluid
Any other suggestions?
Old Aug 2, 2007 | 04:47 PM
thebestofindica's Avatar
Besides what you've listed I would
change tranny fluid
flush coolant
check tires (wear and pressure)
maybe run some seafoam through it for a few tanks to clean things
That should be a real good start
Old Aug 2, 2007 | 08:47 PM
Cynder's Avatar
change power steering fluid as well, that crap gets oxidized quickly. @ 155k it would be a good idea to check your brake lines to see if they've been replaced... also check your bleeder screws... also check your suspension... leaf spring brackets, shackles, ball joints, etc... if I think of anything else I'll throw it up here for ya.
Old Aug 3, 2007 | 12:26 AM
MGDfan's Avatar
Suggestions:
Change the front O2's.
Have the COP's load-tested.
Clean the intake tract /TB /EGR.
Old Aug 3, 2007 | 12:36 AM
twintips_17's Avatar
Originally Posted by MGDfan
Suggestions:
Hey MGDfan..... Ill save ya the trouble of postn another link. I got this one.
http://www.fordf150.net/howto/throttlebodyclean.php
http://www.fordf150.net/howto/clean-...low-sensor.php
Check out those links.
Old Aug 3, 2007 | 05:25 AM
keith97xlt's Avatar
i agree in checking the brake lines. hard line is only a few dollars a foot. good to replace any really rusted sections now.
