Radiator and Halogen lights
Old Jul 25, 2007 | 08:15 PM
dallas63's Avatar
I need to know how to put water in my 2000 F150 and how to put in Halogen head lights my left one is out.
Old Jul 25, 2007 | 08:32 PM
torkum's Avatar
Where did your old water go? The fill tank is in the front on the driver side. I'll let someone else explain the headlight.
Old Jul 25, 2007 | 08:36 PM
twintips_17's Avatar
Youll want to put anitfreeze in with the water. There is a cap on the front of the engine. Im talking right in front of the engine. There is a galolon size bottle on the right front of hte engine that says coolent. Just fill that to the right line. One is for when the engine is cool the other is for when its hot.
As far as the lights. IF you look at your lights from the engine compartment. Youll see a plug with i think two wires, but it might be three. Remove that plug with ease not to break the tab. Then just turn the black round thing a bit and the lamp will just fall out.
When you put the new balb in dont touch it. I was always told that oil from your fingers will make one burst when it gets hot from being on. When you put it in i like to use the alcohal whipes you can buy. Or find them in a first aid kit. Wipe the bulb off and then use the wipe to move the bulb down into the housing.
If you have a problem post it back in here. Ill be on all night.
