Engine oil level
2003 F150 Supercrew FX4 (113,000 miles) Why does the Ford manual say that you should not add oil only unless it is below minimum? I decided to check my oil today after finding a possible rear main seal leak, and found the oil level to be between half full and minimum. The leak is not enough to drip on the ground, but the area around the inspection hole for the torque converter was oily as was the starter. I park in the same place everyday and I have never had any oil on the ground, but I have also never really checked my oil level. Last oil change 1,500 miles ago. Any ideas would be greatly appreciated.
Austin
Austin
Liston to the book - I have two F 150's and they both call for 6 quarts. That reads between half and 3/4 on the dipstick when changed.
DON'T OVERFILL
You'll blow the gaskets or seals..
DON'T OVERFILL
DON'T OVERFILL
DON'T OVERFILL
