2000 ford explorer code reading
Old Jul 20, 2007 | 01:56 AM
rub's Avatar
rub
Does anyone know what this code means P1504?
Old Jul 20, 2007 | 02:18 AM
P1504 Idle Speed Control Valve Closing Solenoid Control Open Circuit
In English, that's the IAC.
Old Jul 20, 2007 | 07:13 AM
torkum's Avatar
Check the wiring connection to the IAC. It also would be a good time to clean it while you are checking the connection. Do a search on IAC for a lot of great info and pics.
Old Jul 20, 2007 | 10:17 AM
projectSHO89's Avatar
Note that is code indicates an ELECTRICAL fault.
Check the connector as torkum suggested. Measure the resistance of the IAC's coil. Make certain it is not open. Should be between 6 and 12 ohms.
If more detail is needed, let us know.
...also, please observe that this section of the forum is for F150s. Your Exploder would be properly covered in the "Other Models" area.
Steve
