mass air flow location
Old Jul 31, 2007 | 06:06 PM
wlsmithjr1960's Avatar
04 f150 super crew 5.4, anybody out there can tell me where the maf is located and hows the best way to clean intake? thanks: wlsmithjr1960:thumbsup
Old Jul 31, 2007 | 07:13 PM
INFireRedF150's Avatar
It should be right behind the assembly that has 5.4L 3V TRITON molded on it. Between that black plastic cover and the firewall, and look for a wiring connector whose harness is on the driver's side of the top of the engine. I found a pic online from the Rousch supercharger install manual. Go to page 16 of http://www.fnsweet.com/docs/2004F150Roushcharger.pdf
Cant answer the question on cleaning, my 2003 is way different than your 2004.
Old Jul 31, 2007 | 07:25 PM
F151's Avatar
The best way to clean it is to take it off.. The easy way to clean it is with carb cleaner through the throttle body.
Old Jul 31, 2007 | 08:59 PM
thanks alot for the info and suggestion, now i can make it look like i know what i'm doing. have a good one!!!!!!! wlsmithjr1960
Old Jul 31, 2007 | 09:52 PM
MGDfan's Avatar
DO NOT, I repeat DO NOT use carb cleaner on the MAF !!!
Far too harsh and will leave a residue.
Use the proper product: CRC MAF Cleaner.
Removal is the best way to do it right & completely.
Let it dry - don't touch the sensor element.
Old Jul 31, 2007 | 09:55 PM
thanks, looks like i have a litty work to do. wlsmithjr1960
