How do you read the VIN ?
Old Jul 18, 2007 | 12:30 PM
treycam's Avatar
I am searching for a replacement motor for my '97 F150. The VIN is 1FTDX1866VNA74402. I understand the 8th digit represents the motor type and because it's a 6 the motor type is Windsor. In searching for the new motor I found that you could have a 6 bolt or an 8 bolt flywheel. Does anyone know how you can tell?
Old Jul 18, 2007 | 12:34 PM
TRUEBLUE2004's Avatar
The dealership might be able to run the vin number and tell you. Other than that you might have to pull the engine and look at it.
Old Jul 18, 2007 | 12:44 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
4.6L motors
Romeo
Cam sprocket attatchment: Bolt and spacer
Flexplate/flywheel: 6 bolts
Main bearing support: Jackscrews
Valve cover bolts: 11
Oil pump: Standard volume
Piston pins: press fit
Vin 8th dig: w
Windsor
Camsprocket attachment: Interference fit
Flexplate/flywheel: 8 bolts
Main bearing support: Dowels ( Prevents main cap deflection)
Valve cover bolts: 14
Oilpump: high volume
Piston pins: full floating
Vin 8th dig: 6
Old Jul 18, 2007 | 12:48 PM
kingfish51's Avatar
https://www.fleet.ford.com/maintenan...ls/default.asp
Old Jul 18, 2007 | 12:51 PM
Raoul's Avatar
25 Year Member
kingfish, I was gonna post that too.
But it only goes back to 2000.
Old Jul 18, 2007 | 12:58 PM
treycam's Avatar
Dealer couldn't help
Thanks for the info. Called the dealer and he tells me I won't be able to tell if it's a 6 bolt or 8 bolt by the VIN. Says I have to physically look at it. To look at it does that mean you have to pull the motor or the transmission?
Originally Posted by Raoul
4.6L motors
Romeo
Vin 8th dig: w
Windsor
Vin 8th dig: 6
Old Jul 18, 2007 | 01:53 PM
Steve83's Avatar
Yes, but depending on exactly whom you spoke with at the dealership, he might not have the slightest idea what he's talking about.
This doesn't address your bolt question, but you might find it interesting.
Old Jul 19, 2007 | 08:59 PM
wdibert's Avatar
VIN Numer
Here is the read out of your VIN Number
VIN Results New Search
VIN: 1FTDX1866VNA74402
World Manufacturer Identifier - 1st, 2nd, 3rd Positions
VIN Code: 1FT
Assembly Country: USA
Make: Ford
Body Style: Pickup
Restraint System Type (Passenger Cars) or Brake Type and GVWR Class (Trucks and Vans) - 4th Position
VIN Code: D
Brake System: HYDRAULIC
GVWR Class: Class D
GVWR Range: 5,001 - 6,000 Pounds
Line,Series Body Type - 5th, 6th, 7th Positions
VIN Code: X18
Vehicle Line: F-150
Body Type: SUPER STYLESIDE
Vehicle Type: Truck/SUV
Engine Type - 8th Position
VIN Code: 6
Engine: 4.6 L
Cylinders: 8
Fuel: Gasoline
Model Year - 10th Position
VIN Code: V
Model Year: 1997
Assembly Plant - 11th Position
VIN Code: N
Assembly Plant: NORFOLK: NORFOLK, VA
Production Sequence Number - 12th - 17th
VIN Code: A74402
Prod Sequence Number A74402
New Search
Old Jul 19, 2007 | 10:29 PM
MGDfan's Avatar
Ummm - that part's useful ....
As opposed to what other choices? Fred Flinstone?
Another source: http://www.fordf150.net/howto/decodevin.php
