Check engine light
Old Jul 21, 2007 | 11:09 AM
adamcardona17's Avatar
Check engine light
I have an '01 4.6. I recently just changed the spark plugs and COP's, all with Motorcraft. My question is I noticed my "Service Engine Soon" light would always come on and then go off at start up, like the air bag light and some others. Now, it does not come on at all at start up. There is nothing happening with the truck, but could this be a bad bulb, or something bigger? If it could be a fuse, what fuse would it be?
Old Jul 21, 2007 | 11:21 AM
SteveStLoo's Avatar
The Check engine light is supposed to come on when you start..
To check the bulb, turn the key to 'Run' while holding down the Odometer Reset switch, and don't let go of the switch until it reads "Test"
then, press the button a few times until it reads "Bulb". It should be right after the Gauge test.
This will illuminate most of the bulbs, the pretty important ones. If the Check Engine Light isnt on, you have a bad bulb.
Old Jul 21, 2007 | 11:23 AM
Thank you Steve. I figured that is what it may be, but I wanted to make sure before giving myself ssome extra work.
Old Jul 21, 2007 | 11:27 AM
Ok, just got done testing the bulbs by holdiing the ****. All the lights came on, including the check engine light. Any more ideas on the cause? Also, is there somewhere I could get a printout of what all those codes that pop up on the odometer are? At least the ones that aren't common sense?
Old Jul 21, 2007 | 04:15 PM
projectSHO89's Avatar
I've posted it before, probably on this site.
SEARCH for "HEC* dealer test mode". Google it if you have to....
Steve
Old Jul 22, 2007 | 07:05 AM
jbrew's Avatar
My 98 doesn't have that test mode, prolly because it's not digital . I just pulled the cluster and checked all of mine .
The run position alone checks the "check engine light" (MIL) in my truck.
