Life expectency
Old Aug 3, 2007 | 12:19 PM
Ohio76's Avatar
Life expectency
What do you guys think will be the life expectebcy of the current generation 5.4s in the f150?
Old Aug 3, 2007 | 01:08 PM
Ash575's Avatar
With good care and regular maintenance.. Big picture... I would say indefinitely.. However something will always wear out or break..
Old Aug 3, 2007 | 02:02 PM
SM's Avatar
SM
Since it sounds like you are specifically referring to the engine, I will say, assuming regular maintenance, no real abuse, and just a tiny bit of good luck, 300,000 miles or more.
Old Aug 3, 2007 | 02:15 PM
scott1981's Avatar
Between 200k-300k plenty of Ford 4.6's and 5.4's running around here with over 100k without a problem. My painter has a 2001 with the 4.6 and almost 250k on his with just oil changes.
Old Aug 3, 2007 | 04:34 PM
RdHammer's Avatar
Ya i think the big decider would be how well it is maintained and treated. If your taking it to the drag strip every weekend then its probaby not going to last, but if you take care of it and dont beat the crap out of it it should last a long time.
Old Aug 3, 2007 | 08:11 PM
F151's Avatar
The body will fall apart before a well maintained motor will terminate.
Old Aug 3, 2007 | 10:08 PM
Labnerd's Avatar
The design life of the new 5.4 is 150,000 miles. Providng there are no catastrophic failures, recommended maintenance has been performed, and the driver doesn't drive it like he stole it, it should last near twice that.
Old Aug 3, 2007 | 10:10 PM
T-B_MN's Avatar
I agree, anyone with a little common sense should be able to get around 200,000 miles out of it.
