OBD11 Code P1507
Old Aug 6, 2007 | 09:47 AM
OLIE's Avatar
OBD11 Code P1507
I get this on my '96 f-150. What is required to repair the problem?
Old Aug 6, 2007 | 02:05 PM
projectSHO89's Avatar
let's see..
Follow the diagnostic procedure in the manual, pinpoint the fault, and replace the part or make the repair..
Old Aug 7, 2007 | 07:07 AM
torkum's Avatar
Its a problem with the IAC. First check the connection and power to it, if that checks ok you can try cleaning it with carb cleaner on the inside. I've not had much luck cleaning them so replacing it would be the next step. One thing not to overlook that can be cleaned is the inside of the throttlebody.
Old Aug 7, 2007 | 08:32 AM
Bootleg837's Avatar
P1507 - Idle Air Control (IAC) Underspeed Error
Description: This DTC is set when the powertrain control module (PCM) detects an engine idle speed that is less than the desired RPM.
Possible Causes: IAC circuit open.
Air inlet is plugged.
Damaged or incorrect IAC valve.
IAC valve stuck closed.
VPWR to IAC solenoid open.
IAC circuit short to PWR.
Diagnostic Aids: The IAC solenoid resistance is 6 to 13 ohms.
Disconnect the IAC valve and look for little or no change in engine RPM as an indication of a stuck or damaged valve.
Application Key On Engine Off Key On Engine Running Continuous Memory
All GO to KE1
