new guy
Old Aug 1, 2007 | 12:41 PM
breeze752002's Avatar
Question new guy
i have a 99 f150---stock run of the mill,etc.--- has 4.6 auto....extended cab 4 wheel drive-- starter locked up. i took out the 2 bolts plus the stud for battery wire... does anyone know how many bolts hold it in.. kind of new at these new conversion motors?
Old Aug 1, 2007 | 12:56 PM
camdenlake's Avatar
Looks like just 2 thought there were 3 must be on the 5.4.
Josh
Old Aug 1, 2007 | 04:56 PM
electricfrank's Avatar
Josh
My 2000 4.6 has 3 bolts that hold the starter in.
Old Aug 1, 2007 | 06:45 PM
keith97xlt's Avatar
there is 3 bolts. that third is a pain in the a$$. youll need a bunch of extensions. have to take that one out by feel.
Old Aug 1, 2007 | 07:24 PM
twintips_17's Avatar
Have fun. When i pulled my starter out the first time( i bought mine used) it only had two in it. I later found out why. It still only has two!
Old Aug 1, 2007 | 08:05 PM
MitchF150's Avatar
Third one is easy if you pull the front tire off and go in thru the fender well... You will still need an extension and a universal, but it's so much easier that way! When you put the new starter in, put this top one in first and it's a piece of cake!
Mitch
Old Aug 2, 2007 | 05:53 AM
jbrew's Avatar
Yeah , That's what I do to Mitch ... It would be biatch trying to get that from underneath. I slid the seven or eight inch extension with a 13mm on the end through the fenderwell and on the bolt. I attached the air ratchet from under the truck . But yeah , you have to that perfect extension length that leaves you enough room to get the ratchet on there.
