water leak
Old Aug 4, 2007 | 08:57 PM
Narvous's Avatar
water leak
I have water comeing down the passanger side of the motor is there a heater hose way in the back?
Old Aug 4, 2007 | 09:41 PM
ONELOWF's Avatar
There are two hoses that into and out of the heater core - engine to firewall. Check those. They are like spaghetti, so if you need to replace one, buy an exact duplicate part.
Old Aug 4, 2007 | 11:19 PM
jbrew's Avatar
The AC drain is there and runs the residual water out an overflow tube , back a little further right side of your trans. Sure your not confusing that with a problem?
Heres a few below, notorious for leaks on that side ..
1. Heater hoses (as said)
2. Heater tube maybe leaking at the O-ring (I have a photo step by step for that fix) - The water will leach from that same spot - left side of motor.
3. Head gasket leak , rear corner left side (same spot as well)
Either one of those issues will direct the leaking water to that side of the motor.
Old Aug 5, 2007 | 09:21 AM
Narvous's Avatar
Originally Posted by jbrew
The AC drain is there and runs the residual water out an overflow tube , back a little further left side of your trans. Sure your not confusing that with a problem?
These are also notorious for leaks on that side
Where is the fix? its not the AC but i cant see where it is comeing from.
Old Aug 5, 2007 | 09:35 AM
jbrew's Avatar
Which of the three possible's - is your problem?
Behind the alternator, top of the block - check to see if the cavity is full of water . It will hold a certain amount in the knock sensor channel if it's the o-ring that is bad.
Old Aug 5, 2007 | 09:49 AM
jbrew's Avatar
In the pic, those two water lines towards the top of the firewall are the heater core lines. They usually leak ate the bottom connector.
Behind the waterpump, there's a hardline(removed in this pic) that runs that knock sensor channle that feeds the heater core thru one of those hosers on the firewall (pictured).
Old Aug 5, 2007 | 09:54 AM
jbrew's Avatar
This is where the O-rings are that leak - IF , that's the prob -
Heater core lines -
Like ONELOWF suggests - you need the exact part. The hoses pictured here have the correct bends but DO NOT include a thrust reducer. A brass thrust reducer protects your heater core from physical damage. IT'S NEEEDED.......... Ford has this incorperated into the supply line and you won't see/find it without knowing it's there.
Metal tube - slides over the O-rings on the waterpump stem. -
Old Aug 5, 2007 | 12:28 PM
Narvous's Avatar
Thanks i still cant see where it is comeing from none on top of motor can only see it runing down the plate beside the cat from under.
Old Aug 5, 2007 | 01:03 PM
jbrew's Avatar
Huh , mine still leaks back there every once in awhile - It hasn't for about 4 months now, but it's the head gasket back by the water jacket.
I cleaned the sh^t out of it and put a little High heat Permatex around it for now as a temporary.
There's allot of stuff in the way and I doubt that you will be able to see where it's originating from very easily. You'll need to pull the plastic inner fender well and have a look. - You might have a leaky freeze plug as well.
When mine leaks it's wet on the head - from the back corner - 2" in towards the front. Also, my starter wires would get wet.
It would never puddle on the ground , but once in awhile I would see a green water drop forming on the wires getting ready to fall
