Oil leak
Old Jul 29, 2007 | 05:21 PM
Ythen57's Avatar
Oil leak
I have a 99 f150 4 x 4 with the 4.6l. I have leaky oil filter lines at the block at the engine....is this a ford add on or did it come from the factory with these lines. I was wondering if there is any cheap fixes for this leak.
Old Jul 29, 2007 | 05:42 PM
keith97xlt's Avatar
is your filter underneath the front bumper drivers side???
Old Jul 29, 2007 | 06:23 PM
Ythen57's Avatar
yep
Old Jul 29, 2007 | 07:21 PM
keith97xlt's Avatar
ok your gonna have to replace those lines. about 130$ at the dealer. i know its a rip off but... dont want those blowing out or there goes your engine. summit racing might have a set for cheaper. you dont want to mickey mouse those.
Old Jul 29, 2007 | 07:24 PM
Ythen57's Avatar
Do the lines come out of that block or does it come together as one piece with the lines and blocks?
Old Jul 30, 2007 | 11:07 PM
Ythen57's Avatar
I just took the lines off of the truck...when I look at the lines they seem okay....Is it more common for the orings to leak or where the hose is clamped on? I was thinking of cutting the hoses off and finding a hose to go over the metal lkines and then clamp them on. Is there alot of pressure going through those line? I found an aftermarket kit and the hoses just clamped on. Any suggestions?
Old Jul 31, 2007 | 05:24 AM
keith97xlt's Avatar
DO NOT SLIP A HOSE OVER AND CLAMP IT. IT WILL BLOW IT. gonna have to replace the whole thing. those are like a/c hoses you cant mickey mouse splice them. if its just the o rings leaking , down to the hardware store for some new ones.think of it this way do you want your entire engine relying on 2-3 hose clamps??.
