- Who is in the 200,000 club?
- how do i scan codes to this year truck?
- 5w-30 to 5w-20
- tune-up
- e fans or Mag exhaust?
- cold air intake
- Engine Code with all 8's for Ford F150
- 2000 Explorer Help--- IAC valve
- 97 f150 4.2 won't start, turned over and stopped. it's not hydrolocked
- Need help form the f150 gods
- What is necesarry when changing gears?
- 5.4 misfire, code thrown for #1 O2 Sensor lean
- Stripped COP
- Cylinder 3 Missfire
- pulley question?
- 1990 f150 4.9
- Trade my truck in?
- How to turn off Check Engine Light
- what to do
- Do you need a tune on a 2000 F150 w/ Airforceone intake?
- code p0174
- Coolant smell in cab???
- 97 F150 rattling when accelerating..
- wohoo BBK is here
- 4.6L Runs, and idles rough. Help
- throttlebody bolt size?
- Hurricane engine from Ford
- gettin my truck back tomarrow
- EGR question
- 4.6 pinging (detonation)
- Question on dealer service/ plugs and coil
- which gets mileage?
- 99 F150 Service engine light on
- How do you check the engine codes???
- replacing starter on 96 2wd 2.3L ranger
- 5.4 3v spark plug....
- Should I remove the Cats.
- Motor mounts (in the middle of pulling)
- Part Number for DPFE sensor?
- Synthetic Oil
- what could cause richness on just one side?
- Bird Chirping sound from Engine JUST GOT REALLY LOUD
- Need Your Help!!
- Motor Fired but Did Not Start, Started on 2nd Try
- Motorcraft or free Quaker State?
- Maintenance schedule
- Problem: Dipstick is dry
- F150 Police interceptor
- 5w30 or 10w30
- This temperature cannot be right
- Replacing Spark Plugs in 5.4L
- 99 F150 5.4L engine miss
- replace my fuel injectors???
- asked ALOT!!
- Finally got my truck back
- 4.6 Throttle Body Plenum
- throttle body question
- Help! My ignition cylinder won't turn!
- P0743 Code Tcc
- Restrictions
- Truck makes a loud humming sound at idle
- Wont start in cold?
- Removing 1999 5.4 timing chain cover
- no start???
- Oil Leak?
- Radiator Leaking due to Troyer Fans
- Accel Super Coils
- Opinions on 4.2 V6
- Starting Problems
- No spark...HELP! HELP! HELP!
- coolant...
- Tried changing Serpentine Belt, Realized Air Pump was NOT MOVING!
- Truck cut off, now it won't start
- Performance lag with 5.4 vs. the 4.6???
- Help me stop worrying !!!! PLEASE!
- Antifreeze confusion
- squeek from front engine area
- Put in a spark plug insert today, not feeling good about it...
- Searching RPM Downhill
- 93 5.0 Rebuild or Replace
- Throttle Body
- crate engine
- Flex Fuel
- MIL code p0406
- Thermostat -- over heating problem
- MAF sensor wiring problem???
- Need clarification on fuel/air requirements.
- oil and low fuel lights
- help,02 locations
- alternator problems
- Supercharge 4.6l
- The diesel F150
- Coil Packs
- Fuel Issue
- installing headers hard?
- Coolant Leak
- Lean on both banks
- EGR ports
- Am i ok....fans,pulleys,belt
- pulling 4.6 for rear coolant leak, any advice?
- 86 starting issues... again
- Fuel Economy
- Has anyone used an AE engine before???
- 05 fx4 weird noise
- 5.4 Cam Options
- NYS Inspection SUCKS!
- Anyone running NOS?
- Engine Missing! Help!
- Engine normal operating temps
- swap i6 for 351w
- Oil in my air filter box?
- 98 150 4.6, Repeated Misfire #4 Cyl, Help!
- Power Steering Fluid
- Plug Blowout Preventative Measures?
- v10 ford engine
- Engine still has a miss !?#@!*
- Hi,NEWBIE 4.6L F-150 PLUGS BAD Condition HELP!
- Where to buy new heads?
- I need Some Help????
- C.O.P.S?????do i need them
- Throttle Sticking, Any advice appreciated...
- 5.4 3v (TRITON) swap into a 91 f150
- Running lean on bank 2?
- Really need assistance on a computer code..
- synthetic blend
- What have you done to your 4.6....
- backfiring
- tps reading?
- flywheel missing teeth?
- Now, I know this is a Ford site, BUT.....
- Save on Gas Milege??!!
- Throttle Body Size
- Please Help
- Ticking!!! I Know Many Threads But
- What Octane do you use?
- Spark Plugs for 5.4 $$$$$$$$??
- Rough Running
- Would you by another FORD TRUCK ?
- what is wrong here?
- O2 Sensor, Cylinder 2, #2
- Newer truck -- old school motor
- 4.6 v8 coolant leaking
- SD Diesel Economy figures.
- Injectors?
- Fuel injectors?
- truck servicing
- Alternator noise?
- P0420 code pulled after plugs and 3 o2 sensors were changed
- knocking and pingging
- misplaced tools...
- quick idle ???
- trans problems help please
- Bosch Ir Platinum Fusion Spark Plugs
- Plug Blowout?
- How are engines expected to stay clean??
- mystery bucking
- Do You Warm Your Truck Up???
- Plug question
- 05 fx4 5.4l ignition problem
- Best oil
- Mayonnaise=water-oil !!!!
- PI - NON PI Swap
- 97 4.6 code p1408
- F150 Sucks.......
- More Codes!!!
- What have you replaced????
- What is best oil for new 2007 5.4 F-150?
- Question 4 Oneloaf -
- What's causing lazy 02 reading from new o2?
- Need Yall's help.... Again....
- Blinking Check Engine Light 5.4L
- I have some knocking/scratching from engine.
- how to make sure it lasts forever?
- Possible bad intake manifold gasket?( Long post)
- #6 Cylinder Misfire
- Limiting Factor
- no power in 2nd gear
- Anti freeze leaks, to much pressure???
- Trop Artic
- Jerking when going up hill
- rebuild on a 4.6
- Balancer Question??????
- Saving Money
- 2007 5.4l 3V
- Coolant Leak?
- Cruise Control Quit
- firing order 98 4.6 trit
- 2004 F150 Won't Start
- Synthetic or not synthetic???
- high RPM belt squeel??
- 99 F150 4.2 engine stumbling/missing
- engine noise
- Moding my SCrew 4.6
- EGR valve?
- Poor Gas Mileage and drive under load..Error 0171 and 0174
- Niehoff COP Terminals
- fuel mileage WOW!!
- Changed Plugs at 100,300 miles, check out the pics
- Rear Pinion Seal
- Sounds...
- Engine startup recording - shot with pair of $200 condenser mics
- 97 F150 4.6 Will Not Start
- Thinking of Switching intake manifolds...
- Clatter on cold start - happened twice
- funny feeling in rearend
- Serpantine Belt vibrations??
- Misfiring
- [img]http://www.f150online.com/galleries/thumbs/9275-13218-183273-thumb.jpg[/img]
- Spark knock?
- need help running rich, have codes
- Swap out Windsor for Romeo
- Air Hog Vrs. K&N
- +20 HP for $10?
- Cold air intake ?
- diesel ticking noise
- Milky Oil Cap
- what kind of cylynder head is best
- is the EGR really not needed
- Coil Pack bolt help
- 98 5.4 P0304 #4 misfire fix
- need yalls opinions
- Expy engine vs. F150 engine
- Even the new O2 is sluggish! Help!
- Check engine light - EGR Questions
- 99 5.4 intake manifold
- Coil Pack
- Help!
- 5.4 2v vs. 5.4 4v engine
- heat sheild experiment for AF1 on my Expy
- coil pack bolt HELP
- 4.9 l serpentine belt problem need help
- Coil Pack bolt HELP
- Rear axle seal leaking
- Pre-PI head engine/ PI intake manifold alignment
- 98 5.4 just dont have the kick it use to
- Supercharger install onto 98 Expedition 5.4
- tb,iac and egr port cleaning results
- Fuel problems.
- Squeal or Whistle
- 4.2 4.9 engine swap out
- Lightning Short Engine Urgently required....
- Anyone No where I can order ?
- More new Romeo Motor parts up for grabs
- Got a code P0230 primary fuel pump malf...
- Watch those spark plugs!
- Fuel filters
- Here We Go 2007 F150 FFV 5.4 Recall
- cheap cops on ebay again
- Nut size, power steering line
