need help asap !!!!
need help asap !!!!
We are headed out of town this weekend and was loading the truck up today and i started it and noticed that the battery voltage on my edge was reading 13.4 to 13.9 volts. It always is between 14.1 to 14.5 volts. Does this mean the battery is about to take a crap? I live about 20 miles from the city and dont have time to run it to autozone tonite to get them to check it. Im hoping yall can help me. Is 13.4 to 13.9 still acceptable or will i be pushing my luck? Thanks guys
by the way its still the original MC battery from 03 and the truck has 110,000 miles on it
i notice that on my gryphon all the time...85% of the time it reads 14.1v..15% it will read 13.4 sometimes as low as 12.9... if im no mistaken i think it depends on the temperature and humidity...but thats my guess
thanks for the quick reply, ive had my edge now about 10 months or so and i had never seen it go below 14.1 volts. Temps ranging from the 20's to the 100's and never went below 14.1. One thing i forgot to mention is the last month or so when i start the truck all of my guages peg out like the tac goes to 6 grand oil pressure and temp gauges all peg out to high then after about 10 seconds at the most everything will go back to normal.
You have either a connection issue (most likely) a bad battery or a bad alternator. Start with the connections. Clean the battery terminals. Check the connections on the relay alternator and the starter. The starter wire corrode so check for that. if that dont fix it have the battery tested and then the alternator.
If your gauges are sweeping, that's a bad sign and good indication you'll be needing one soon. But! That could also be a bad connection. And sometimes a battery can go 8 years, I just use the 5 year rule. Give my old one away if it's still good.
EDIT: Jethat beat me to it
thanks guys i just checked all the connections and everything seems to be good. The battery terminals look VERY clean. Im going to go get it checked tomorrow before we leave, i just dont want to be 250 miles away from home and the thing take a crap. Guess after 8 years i cant grip can I ? thanks for all the quick replys and suggestions/
I've been using Walmart batteries, -no problems with those so far. From what I hear, Motorcraft isn't that great anymore as far as batteries. If your in the market, I would search some threads in this forum or start one of your own. I think there was a manufacturer change with the Motorcrafts ? Iduno exactly,- somethings up with them tho.
Interstate use to be good as well. I'm on my second Walmart battery in the truck (the 98). My first one is still being used by someone else. I replaced that two winters ago just because it was close to 5 years old. So Walmart batteries are the only ones I can vouch for.
I read 14.1-14.5 myself but usually 14.2 average. Mine crapped on me at campus at 11pm... thank god the mrs was there
Coy, the tuners take up more juice on start-up and I think the trucks require like 12v or so (I feel like I read that on here?) Go with your cut and replace that bad boy. Mine lasted 6 years.
you did not mention if the truck was running, if you had the doors open for an extended time and not running, you drained the battery.
heavy charging will show a lower voltage for a short time, the longer it takes to charge up the weaker the battery - replace it!!!!!
