need help asap !!!!
Old Apr 30, 2010 | 07:11 AM
MGDfan's Avatar
Originally Posted by jbrew
Who makes Walmarts batteries, anyone know?
Old Apr 30, 2010 | 07:16 AM
MGDfan's Avatar
I read 14.1-14.5 myself but usually 14.2 average. Mine crapped on me at campus at 11pm... thank god the mrs was there Coy, the tuners take up more juice on start-up and I think the trucks require like 12v or so (I feel like I read that on here?) Go with your cut and replace that bad boy. Mine lasted 6 years.
And no. The tuner does not take more juice at startup.
Yer interior lamp draws more than that.....
Old Apr 30, 2010 | 07:49 AM
jbrew's Avatar
Originally Posted by MGDfan
No, that's the Abonzziii Battery guy.
Old Apr 30, 2010 | 08:00 AM
MGDfan's Avatar
Old Apr 30, 2010 | 08:28 AM
jbrew's Avatar
Old Apr 30, 2010 | 08:37 AM
Norm's Avatar
Old Apr 30, 2010 | 08:59 AM
jbrew's Avatar
Geezzz... Okay fine, I'll answer my own damn question or try -
Alright, so who makes NEverstart ?
Old Apr 30, 2010 | 09:46 AM
MGDfan's Avatar
http://lmgtfy.com/?q=who+makes+everstart+batteries
Old Apr 30, 2010 | 10:01 AM
Originally Posted by FF301
you did not mention if the truck was running, if you had the doors open for an extended time and not running, you drained the battery.
heavy charging will show a lower voltage for a short time, the longer it takes to charge up the weaker the battery - replace it!!!!!
All I did was open the door shut it and start it up. The truck had been sitting for about a week.
Thanks that chart is what i was looking for!
Old Apr 30, 2010 | 10:08 AM
I have an interstate mega tron plus battery. Good battery.
Old Apr 30, 2010 | 10:17 AM
jbrew's Avatar
Code58 covered some of this -
The majority of car batteries are created by 3 manufacturers - Delphi, Exide and Johnson Controls Industries. Delphi makes some EverStart models sold in Walmart and ACDelco. Johnson Control Industries makes Duralast seen in Autozone stores, Diehard - sold in Sears, Kirkland - the Costco brand, Motorcraft - which Ford sells, some of the EverStarts, and Interstate. Exide makes Exide batteries, Champion, Napa and even a % of the EverStart batteries. A car battery is one of the few things that you will most likely have to replace if you own a car more than about 3 years. Most other parts and accessories will last longer, but the battery in a car needs replacing every 3 years or so. If you need to get a new battery installed, go to Goodyear, Sears, Firestone or Pep Boys. All these car stores carry large inventories and can install your battery onsite. Other retailers like Target, Kmart, and Walmart might offer cheaper prices for their batteries, but rarely do they install them.
Copied/Pasted from here -
http://www.galttech.com/research/car...ar-battery.php
From the lead MGD posted above
Old May 2, 2010 | 09:23 PM
update
well i went friday morning and had oreillys check the battery and it turned out bad, so i went and got a Everstart from walmart and took off on our trip. About 90 miles out in abilene heard a horrible sound and pulled over and the alternator had froze and took the belt with it. So got a New Everstart, New Alternator and a gatorback belt. She good as new now
Old May 2, 2010 | 09:57 PM
jbrew's Avatar
Geezzz, what's the chances of all that happening at once lol. Well, glad you got her fixed. I would get a new tensioner as well. Actually, if you go to the Gaterback informational @ Rock auto, that will inform you as to why you should change the tensioner at the same time you install a new belt. Tensioners aren't that much and it's good preventative maintenance.
Personally, I'd replace the idler as well. When they go, it could take a chunk out of your Timing chain cover. Sounds like it's time for that.
Old May 2, 2010 | 10:04 PM
Thanks for the tip i will definetly get that tensioner and the idle never thought of it but it makes since
