5.4 Multitude of issues
So here goes... I have an 01 SCREW with a 5.4 that has a nice 208,000 miles or so on it, back in October of last year I had a COP go bad #5 I believe, so knowing the milage and anticipating the rest going bad I had them all replaced. At the same time I had the plugs changed as well.. Problem solved or so I thought.. In the last month I had not 1, not 2 but 3 plugs blew out of the heads, breaking the COP at the bolt and making a loud ride home for about 5 minutes, each time I had to sent it to a garage and have a time sert put in and replace the COP.. Kicking myself for not doing it sooner.. I pulled the remaining COP's and checked the plugs, found 2 more that were litterally finger tight. Tightened the rest to the 20ft/lbs and back on the road..
Yesterday the truck started having a serge and sounded almost like an exhaust leak.. No problems ideling in park just under a load.. I dont know if another plug is about to go or something else is up.. Code p1405 popped up and Im not sure what it is.. of course the code cleared after reading it still having the same problem..
Any thoughts or opinions are welcome.. Thanks
Jbrew is an expert on these problems, hopefully he will chime in with some advice. If he doesn't, you might send him a PM.
That will be my project for the week, I don't believe they used antiseize but I will ask tomorrow, I think I'm better off taking things in my own hands, never a better situation than being able to blame noone but yourself.. I didn't mess with the plugs that were replaced with the timeserts should I? I'm not sure if I should be wrenching on them seeing as they were a problem once already...
