Help.. 17 Trouble Codes
Old May 13, 2010 | 09:47 AM
Haschr's Avatar
I have an 04 5.4 supercrew 175,000 . rough idle... and 17 codes ouch... That just sounds bad.. Is this something I should take to the dealer..Or attempt to fix on my own?
p0012
p0172
p0174
p0300
p0301
p0302
p0303
p0304
p0316
p2196
p0122 pending
p0223 pending
p0340 pending
p0351 pending
p0358 pending
p2110 pending
p2197 pending
Old May 13, 2010 | 10:24 AM
jbrew's Avatar
Why?
Did someone wash the engine bay, uhh, -real good!
I would start with the plugs, -Motorcraft. Jump on ebay and order 10 coils (2 spares) since their so cheap and the chances of getting a a bad coil out the box seems to be good.
At a 175k, the engine needs to be gone thru. O2 sensors, PCV system and whatnot. This one might be pretty pricey if you take it in.
Surprised it's running at all with the entire first bank (right bank, passenger side)on the blink.
Old May 13, 2010 | 11:14 AM
It would help to know if plugs , fuel filter anything else has been changed. Throttle body cleaned? What maintenance?
Old May 13, 2010 | 11:40 AM
Haschr's Avatar
Changed motor oil every 3k change tranny fluid and air filter. Thats it..
Old May 13, 2010 | 11:47 AM
Labnerd's Avatar
Depending on how long it's been running bad, it's probably a better idea to trade it in on a different one. You'll need the plugs changed....if they can get them out without breaking, O2 sensors, fuel filter, complete PCV system, throttle body replaced, COPS, and most likely the CATS are bad now. If done at a dealer, the cost would probably be about what the truck is worth with yer mileage. Considering you've done next to no maintenance on it, I'd say ya got yer moneys worth out of it.
Old May 13, 2010 | 12:21 PM
MUD DIGGER's Avatar
time for a new truck dont even bother fixing that if you bring it to a dealer could cost as much as 5000$ or more trade her in, you got her moneys worth out of her
Old May 13, 2010 | 12:34 PM
Haschr's Avatar
I'm not ready to take her out to pasture. I understand i'll get bent over if i take the truck to the dealer.. I'm pretty handy and i'm willing and want to do the work myself. Just need to be pointed in the right direction.. CEL came on about 2 days ago. I limped it home and parked it, about 20mi.. If the repairs are simple bolt ons ( plugs sensors filters ect ) I can tackle that.. I'll start with the plugs and fuel filter this weekend..
Old May 13, 2010 | 01:34 PM
With that many codes, a good possibility is one of the main harness plugs going through the firewall. It could be loose or corroded. I would not throw parts at it till all electrical connections are carefully checked.
Old May 13, 2010 | 01:38 PM
Veteran: Army
wow
Old May 13, 2010 | 01:48 PM
jbrew's Avatar
Sounds good. Yea, I would do the same. Do a good visual on things as you go. Like the wiring and such. Go from there. Coils O2's. Update your maintenance items first , unless you find another problem along the way. Cats = She won't run right if one is bad (passenger side in your case).
Before you throw a new set of plugs at it, it's a good idea to compression test it. You might be forced to pasteurize. That should give you an idea on your overall engine health anyway. Follow Fords procedure when doing so. Jump on ebay and purchase a Ford Service DVD. You'll want that, very handy.
Good Luck
Old May 13, 2010 | 01:51 PM
MGDfan's Avatar
wow
Pffft .... ain't nothin'...
I once hooked up an Edge to scan a truck runnin' right poorly,
and instead of some codes, the display just showed, in order:
http://www.edgeproducts.com/product_...cle-pdf-41.pdf
Followed by a string of
Old May 13, 2010 | 02:03 PM
Are you aware of the breakage problem witrh the plugs? Be sure to follow the TSB in removing them and have the Lisle tool handy. I would change the boots and the coils too.
Old May 13, 2010 | 05:28 PM
jethat's Avatar
Sound like you let the truck go to crap. Trade it in..
Old May 13, 2010 | 06:35 PM
Toyz's Avatar
p0012
p0172
p0174
p0300
p0301
p0302
p0303
p0304
p0316
p2196
p0122 pending
p0223 pending
p0340 pending
p0351 pending
p0358 pending
p2110 pending
p2197 pending
That may be a record on a still running truck.
I would guess the same, if they all popped up at the same time. Not that you don't need a full tune up cause you do.
Old Jul 10, 2010 | 04:40 PM
Haschr's Avatar
Well, Been working on it off and on the last 2 months... Thanks to glc i pulled the harnesses from the pcm. and notice the rubber gasket ( green ) was wedged in between the red outer plastic cover and the actual plug ( if that makes sense to u ) it seems the harness wasnt making good contact with the pcm.. I have no clue how that happend. Only took it to the stealership for oil changes.. Fixed that and ran codes and only came up Tps code. So with anyluck ( which i have none ) it was the harness
Figured might as well do general mantainace ( only been 175k ) got the plugs, fuel filter air filter and tps all motocraft. In the process of changing the plugs 5 out of the 8 broke. Pulled out 4 so far. On one of the plugs the bottom handle ( metal strap looking thingamajig ) broke off ( nice ).. It's gotta be sitting right below the plug hole. I'm gonna try to get it with a magnet, or suck it out with the shop vac. last resort hit it with compressed air. ( i plan on doing it to all the cylnds just to be safe ).. Any other ideas?
