5.4 build
Old May 7, 2010 | 10:34 AM
f150greg's Avatar
5.4 build
So a few weeks agoni decided to start a new build
for my f150. I purchased a 5.4 block from summit racing and have it on an engine stand in my garage. I know that I want to keep it naturally asperated, and have around 400-450 ft lbs of torque. Horsepower isn't too much of a factor to me only because I understand the basic principle of engine operation. I also would like to use the 2v heads. I live in California so I don't want to risk getting my truck impounded and crushed for illegal engine modification. Any suggestions?
Old May 7, 2010 | 10:39 AM
Veteran: Army
get the trick flow top end kit, and the pashcal stroker kit (the smaller of the 2)
also get yourself some cali legal headers (equal length shorties) run yourself 2.5 inch dual exhaust with an H or an X pipe with the mufflers of your choice, 42# injectors, a larger fuel pump, a 90mm MAF and a solid tune
Old May 7, 2010 | 10:44 AM
Toyz's Avatar
Is that seriously true? "illegal engine modification" Gayness
California is like the state with some of the biggest classic/hotrod builders and bike builders.
Old May 7, 2010 | 10:54 AM
Veteran: Army
as long as he maintains smog equipment and doens't run long tubes he'll be fine
Old May 7, 2010 | 11:16 AM
Toyz's Avatar
Gotcha.
I was curious when a friend and I were talking about his built 91 stroker stang. He mentioned it was 50 state legal including California. Wasn't quite sure what the parameters of that meant.
I want to see how this turns out. Sure makes me wish I would have kept my old motor seeing all these build threads.
Old May 8, 2010 | 01:33 PM
f150greg's Avatar
ok so $2900 for the top end kit and $2000 for the stroker kit. I feel like this auto parts business is something i should get into. What about intake manifolds what options do I have there? From what I hear the stock piece flows pretty good. But i was thinking about making a custom intake using he lightning manifold. Just so I can have the dual bore throttle body. Anyone ever done this?
Old May 8, 2010 | 02:52 PM
Veteran: Army
been there done that wouldn't clear my supercharger so it's up for sale
Old May 8, 2010 | 04:23 PM
Veteran: Army
there's always this option if you're willing to do the work to make it run
http://www.frpracn.com/
Old May 9, 2010 | 03:53 AM
f150greg's Avatar
How much you want for it?
Old May 9, 2010 | 12:47 PM
avfrog's Avatar
I always liked the looks of those sheet metal intakes and valve covers.
Old May 9, 2010 | 03:06 PM
f150greg's Avatar
I was just told that this block I have isn't a "performance block" I obviously know this because I didn't want to throw down the $3000 for the aluminum block. But Ive heard of cast iron blocks surviving up to 1000hp and beyond. I have a feeling that this dude is an idiot and doesn't know what he is talking about. Am I ok with this build with a cast iron piece?
Old May 9, 2010 | 03:16 PM
avfrog's Avatar
^ Yes. Your not going to make anywhere near 1000hp.
Old May 10, 2010 | 03:09 PM
Veteran: Army
make me an offer, I used the lightning plenum on another project
