97 f150 fuel relay probs
Old Apr 25, 2010 | 07:30 PM
LordRedstone's Avatar
Got a 97 f150 w the 4.6 triton. I thought maybe feul pump went in it, dropped the tank and replaced it w another 1 that i had. Still wont start. Checked the relay and fuses they seem all ok as well. Dropped the tank again, with the tank off and lines off i hooked up the fuel pump to see if it was working and it wasn't. I pulled the relay and jumped it and the feul pump works. I have tried different relays with no luck. Any suggestions...
Old Apr 26, 2010 | 08:24 AM
jbrew's Avatar
Did you reset the inertia switch ?
Old Apr 26, 2010 | 09:49 AM
yes I tried that as well with no luck..
Old Apr 26, 2010 | 02:22 PM
DYNOTECH's Avatar
Check your fuses again. Sometimes they appear ok but are blown. Actually I guess I should have asked how you jumped it out. Did you use the same circuit or an alternate 12v source?
