Code po316
Old Mar 31, 2010 | 10:27 AM
sultini's Avatar
Code po316
Changed plugs about a week or so ago erveything cool, yesterday started running rough SES light comes on, scanned and PO316 comes up something to do with the gas vapor. Little blinking symbol c and ev.
I probably knocked something off when changing the plugs.
Any advise would be appreciated.
Old Mar 31, 2010 | 10:45 AM
jbrew's Avatar
I remember you. Yea, good luck with that. Couldn't happen to nicer guy.
Old Mar 31, 2010 | 10:51 AM
sultini's Avatar
Don't know why your acting like that with me I never said anything to offend you that I know of. If I did I apologize if it's not to late. I did get off track on a couple issues and people, Don't we all from time to time even you j??
Old Mar 31, 2010 | 12:34 PM
jbrew's Avatar
Yea, well they are friends.
Did you use Motorcraft plugs? PO316, - Bad coil or bad connection on the B+ wire at the coil.
You should have another code besides just the 316. The other code directs you to the cylinder #.
Old Mar 31, 2010 | 12:47 PM
sultini's Avatar
I sent PMs to people I offended apoligizing to them.
Yes I used the exact OEM plugs from the dealer all numbers the same with gap.
Thanks for the tip will check it out.
Old Mar 31, 2010 | 12:55 PM
jbrew's Avatar
Could be a bad connection , - coil balde to coil spring. If you used anti-sieze, it could have dribbled down and fouled the plug on a 4 thread head.
Old Mar 31, 2010 | 04:47 PM
sultini's Avatar
Thank you
Misfire on #6 defective COP.
Thanks Again Sultini
