Convert a f150 to diesel?
Hey guys im new here but i cant find any info about swapping in a turbo diesel power-stroke into my 2000 F150. i bought it dirt cheap with no motor. I saw people putting in cummins diesels but i want to go the ford route. Would a 2000 f250 turbo diesel fit in and hook up to the tranny? i would prob need the ecu also. unless its a huge project and a 5.4L V8 is easier.
thanks guys
Ryan
thanks guys
Ryan
Oh, you're stock trans won't survive any swap like what you are thinking... What was the original engine in the F150?? If it was the 4.6, then your rear end is only a little 8.8 and if it was a 5.4, then it would have a 9.75, but you'd want the full float 10.5 inch one from the SD that the diesel came from if you want it to survive as well....
Even a semi float 10.25 rear end would have a hard time with that kind of swap...
Mitch
Mitch
o ok it was a 5.4L. I have a lancer that im building as a track car so this truck would be perfect. Im looking for a simple swap, something reliable and easy but if the tranny needs to be swapped and a whole mess maybe ill stay stock. I already have a project car lol. anyone kno where to get a motor at a decent price? i kno junkyards might have some.....
actually how hard is the 4bt swap? and on the stock tranny??
If your puttin a diesel in, do a cummins, but you'd have to get a dif trans. if you wanna do a PS then your going to have to put a solid axle in the front forsure and do away with the ifs. If your truck was a 2000 5.4, it should have the 4r100 transmission, Which was used in super duty applications too. That trans(4r100) will handle a 7three.
It wouldn't be worth it for what you want tho. it gonna require some customization.
I'd put a v10 in...that would be the best option imo.
I don't thik that transmission will bolt up plus that won't be cheap. The transmission he's got(if its a 4r100 forsure) will handle the power a 7.3 makes and it will bolt up. They put the 4r100's behind the 7.3 from the factory. I wouldn't spend any money you aint gotta
Just to throw some info into here:
I have a 2000 5.4 and it came with the 4R70W not the 4R100. I'm pretty sure the only 2000's with a 4R100 were the California ones since the 4R100 is better on emissions for some reason.
Secondly, a gas 4R100 will not bolt up to a diesel anyway. I'm almost 100% sure the bell housing bolt pattern is different between the two. The internals are the same, but the bolt pattern differs.
I'd just drop in a 5.4 honestly. It's cheaper, definitely easier because the original motor is a 5.4 in the first place, right? and a 5.4 can pull a single car trailer no problem.
- Erik
- Erik
- Erik
- Erik
YOu may be right. i had a 98 f150 5.4. it had a E40D, basically the older version of the 4r100, but the same transmission. maybe the bolt patterns are different, but thats why i think he should consider a v10.. Get one of thos for under 2k. Not that much of a price difference between a 5.4 and 6.8...both lightly used
- Erik
