02 5.4 plug tourq
ok i'm new and not good at the search function. What's the tourqe spec for a 02 5.4 in a F-150 if it matters. my Hains manual says nothing and cant find here with the search.
ALSo i got Motorcaft Platinum Iridium plugs, are they ok, good, bad, overkill, just right or what???
ok thanks. While waiting for an answer, i did some searching and see all sorts of "specs" i see 11ft lbs, 12, 11 to 16, no tourque needed just finger tight plus 1/8 turn etc etc. who am i to believe. from what i've read 28lbs is very high, especially for alum heads. Not saying your wrong, just way above what i've read here and other internet places. now i'm very confused and even more unsure
4 thread aluminum heads have been tested to withstand 100' lbs of torque. Look at how many posts I have. I would have been burned at the stake by now if I gave out bad info lol. But, I know what your saying, others will post.
And where did you see 11-16ft/lbs? I think the manual calls for 18ft/lbs with antiseize.
But due to the spitting plug issues to use 28ft/lbs dry.
oops, fixed
Ford has not changed their original recommendation. The 28 ft/lb comes from the guys at blownoutsparkplug.com. They also recommend NO antiseize, use nickel-plated Motorcraft plugs.
Glad you did wait. What GLC told you is right on. Those guys do it for a business and know what they're talking about. 28 lbs is definitely not to high, but enough torque to maybe keep from blowing a plug. 14 lbs is almost nothing. The problem is the Ford recommended 14 is so low that it gives the plug a chance to start to loosen and then the intake and compression damages the threads as it gets looser and looser. The aluminum head expands away (out) from the plug because aluminum expands a lot more than steel and the stupid 14 lbs just isn't enough to assure retention.
