- Changing fuel filter
- 98 f-150 cracks in doors
- 4.6 pinging & diesel sound
- Scratching or scraping sound . . .
- Check Engine Light (misfire on 8)
- Please Help Me!!
- Squeal
- I changed my spark plugs...
- Serpentine Belt Change
- 4.9L Exaust Sound Under Load
- 1987 302 EFI can't determine fuel filter
- took my IAC off...strange....
- Intake sensor mod, anyone tryed them?
- Turbo-Net, fact or fiction?
- Where is the IAC valve located????
- Help!!! 4.6 forgot how to idle...
- Motor oil
- New Diesel Noises
- What the heck model truck is this 2004 F150 funny looking ext cab ???
- maf, egr ??
- living with ford spark plug blow out problem
- 2001 Supercrew Dies
- best gas
- 5.4 Cold Start / Blue Smoke
- engine knock
- air filter/ait intake
- pcv valve making noise
- 2002 supercrew tapping/ticking on cold start
- synthetic oil
- 1st time ford owner with O2 question?
- Seriously weird engine noise....please help
- Newbie
- Plasma Booster From Ignition Solutions
- DPFE sensor hoses?
- tune up mileage
- Can I put a Lightning engine in a F150?
- Times
- vacuum problem?
- Who is right? me or Joe?
- strange problem
- First highway trip MPG!
- 0w-20
- infamous front end squeak
- Throttle Body Spacer Good or Bad ?
- Where to install Water/Tranny sending units?
- Humming noise
- help!!!!! truck wont start!
- Death to all Corporations...
- Poor-mans FIPK
- sudden loss of fuel economy
- PCM question
- Looking for a Ford mechanic in VA
- radio inerference from fuel pump
- Idle Vibration
- 97 F150 4.2L Won't Start
- Pro Mod and Super Pro Mod engines!
- Decided To Make It A Whole Thread
- Spark Plug Change - Now a Miss
- Spark plug torque
- Initial Engine Rpm
- FollowUP - Fixed 97 F150 4.6L V8 will die at idle. DRB2=P0401 EGR Insufficient Flow.
- Mobil1 0W20 Sightings
- Question about new 5.4 3V
- air intake manifolds
- Fan Clutch Question
- '97 f-150 4x4 4.6L - Cranks, but Won't start
- Pulling the Passenger Head in a 5.4 - Looking for tips
- Swapping 302 To 351w
- air intake mod
- reset the computer.. can anything go wrong?
- Pinging
- Power Hungery!!!!
- 97 f150 4.6l dies at idle. P0401 EGR Insufficient Flow Code!!!
- bad gas
- Help with an oil change
- Fuel injector cleaners, good or bad?
- Pingy Noise Upon Cold Start.........
- Auterra OBD2 ?????
- Strange problem.
- 1999 F150 5.4L oil leak
- re rough idle
- still having problems!!!
- Occasional White smoke
- Manifold gasket?
- Temp Sending Unit
- headers worth it?
- Curious on a 5.8
- power steering loss
- Random Rough Idle and fuel Tank Venting Through Cap????
- Who says 4x4 is slow?
- Oil warning light
- need advice
- Truck won't start..sometimes
- Over 97,000 an Going
- 300 ci question
- rattling mystery
- How long do these engines last??
- 4.6 problem
- new heart new engine
- Max Torque Per Cubic Inch @ 93 Octane?
- Help, My 98F150 dies out
- Bad gas?
- engine fan cycles every 12 seconds
- Kinda wierd maybe related to Creole
- is the oil pan draon plug located just behing the front axle, right before the tranny
- Crankcase Breather
- PO172 Code
- Pinging and Diesel sounding
- Response
- Help!
- hard to start sometimes 1997 f150
- why are 02 sensors so dang much
- truck keeps dying
- power steering leak
- How to remove starter on 4.6?
- Lightning Mass Air Meter
- Wierd happenings
- Throttle Body Elbow?? Ported Matched
- shraeder valve
- Oil Changes by Time
- Trouble, Check engine, etc.
- 1998-1999 SC flairside project
- Stinky exhaust, what fixes it?
- Pinging, what to try next?
- Errors P0171 & P0174
- 1997 Ford F-150
- Fuel xyz treatment?
- What's your 0-60 times?
- 4.6 Liter Engine's
- A couple of questions.
- UPDATE on rough idle problem
- fuel pump pressure trough lines
- Please Help - 97 4.2L - hard starting
- Looking for original specifications on my 99
- finally stopped whistling
- 1997 F150 4.2 Coolant leak
- 5th Alternator in 5 years, ?????
- 5.4 rattle
- mpg w/ low engine
- injector cleaner-when/should I
- Heatshield rattle?
- Any one using just regular Mobil 5w30 oil
- Cylinder head leak article no. 02-22-7
- Pcv Replacement
- MPG 4.6 vs. 5.4
- 1151 code
- 97 f150, 4.6 will not idle
- 5.4L Engine Rebuild kit?
- How do i drain the Radiator?
- It wont start
- coolant leak
- Amsoil switch
- What else should I have replaced by now?
- 5.4 Oil Leak
- AMAZING motorcraft battery
- Small Block Fords!! Best Ever?
- Question about a 5.4
- Propane Injection??? anybody help
- Any diff in Walmart oil and Castrol 5w30
- Where is the IAC on a 4.6L??
- Help me out...truck wont idle!
- Minor Engine Coolant Leak
- Engine Replacement
- What would be involved if i needed to rebuild my engine
- 5.4 in an Explorer
- Anyone Gotta Fix for the PCV Boot?
- Help _ Won"t Start
- How to remove a 5.4? Fit from Hood?
- What Type of Plug & Wire Set
- Spark Plug Thread Repair
- heat blower on with ignition switch off
- port & polished heads..
- PS leaking
- power steering noise ?
- tata tata tata tat tat tata ... maintenance?
- Advice with 5.4L Engine
- Under Pulleys for 4.6
- Clutch Fan Removal / Electric Fan Install
- 4.6 coil pack & water
- Happy Holidays
- Starter problems
- Help me pleaseeeeeeee
- Power Pulley Questions??!!
- I Need My Head Examined
- 1986 Ford F150 Left side not firing!!! Help Plz!!
- Gas Tank Wont Fill!!
- Hav anyone seen this: Nitrous Oxide MiniBooster Ford
- clogged injectors
- new 3 valve specs?
- Smoking problem with 2000 F150
- Spark Plug Wires????
- 4.6 cuts out / hesitates
- new to the format here
- fuel pump
- What plugs,wires etc?
- 4.6L tapping valvetrain?
- blown Plugs
- 5.4 rattle at idle
- Horsepower
- Plug blow out tally,only post if you had a plug blow out
- Making the move to electric fans
- Idle Problem
- 300 6 engine hop ups
- Price Comparo for Servicing
- oil pressure
- I think the head has to come off
- Thanks All of you that answered my thread!
- Who is in the 100,000 mile club?
- This is scaring me!!!!
- sick 97 f-150 4.2 (ideas)
- Good amount of smoke coming out of exhaust
- Urgent Help Needed Please
- how much should i pull in o/d
- 2nd gear RPM loss
- Electric Water Pump Or Pullys?
- Extended Warranty Question
- 2001 5.4 Starting oddity
- Did a "mini-tune up" today......
- FIPK filter kits
- Oxygen Sensor Location
- Pullys? Do they free up 12HP?
- Cold weather miss...
- throttle bodys
- Engine studder at low RPM's
- Antifreeze smell
- Engine Missing during Acceleration
- stumped by oil leak from air cleaner
- What's happening when I "Punch It"?
- Loser smashed my F150
- 5.4 litre problem
- Fixed the "Ping"
- K & N filter install
- Need a little advice on Coolant change--->
- Need a little advice on Fuel Filter changing--->
- Accel Foam air filters
- oil change easy question
- 4.6L redline
- What Brand Of Oil Filter Are You Using?
- start up whine
- Fuel economy
- '02 SuperCrew Wouldn't Start??
- starter noise
- #3 Cylinder Running Lean
- Throttle body Q.
- should I be worried about blowing a plug on my 01 5.4?
- Think Before You Chat
- Throttle Body Spacer and K&N Drop in
- Pinging 4.6 owners, one more thing to check out
- Recent experience with Coils and Plugs
