Low Idle RPM'S
Low Idle RPM'S
I am not receiving full alternator output because my 05 F-150 is idleing below 850 RPM'S. I have a CAI and exhaust, although I am not sure that those mods have anything to do with it.
What is the fix. The dealership says this is normal, but I doubt it.
It is a great dealer ship to. They replaced my whole front brake assembly for no charge
Anyone have a quick fix?
Dealship is saying that a low idle RPM is normal? He might be refering to normal for a CAI and Exhaust.
By not receiving full output I mean that when i am sitting at a stop light and the lights are on, they dim alot, and I can see the lights behind the gauges flickering (dimming quite often)
Since it's still under warranty, I wouldn't touch it. Take it to the dealership and tell them you want it fixed. If they give you the run around, then contact the main Ford office and give them a bad review. I have a 97 F-150 and the lights don't flicker, so I would have to say that this is not normal. Just take it back.
Your idle sounds about right (actually it sounds kind of high, although Im not really sure what the idle on the new F150s is). My truck idled around 600 RPMs (in drive) before the XCal2, now it idles around 700 RPMs with the tuner.
Your flickering is not the fault of a low idle speed (will upping the idle speed fix it? yes but that is only covering the problem...something else is wrong).
Your truck is still under warranty...the dealership should fix it.
