E-85
Old May 2, 2006 | 09:54 PM
DoneThoo2's Avatar
E-85
Is there a way to make a regular gas burning engine able to run on E-85?
Old May 2, 2006 | 09:55 PM
Quintin's Avatar
This has been asked over and over and over as of late. No, it's not readily possible to make a gasoline burning engine run properly on E-85. Will it run on E-85 regardless? Yes. It'll slam the O2s lean and turn your check engine light on though.
Old May 2, 2006 | 10:39 PM
NKENN's Avatar
According to an article entitled The Truth About Biofuels (How Far Can You Drive On A Bushel Of Corn?) in the May 2006 issue of Popular Mechanics . . .
"E85 has an energy content of about 80,000 BTU compared to gasoline's 124,800 BTU. So about 1.56 gal. of E85 takes you as far as 1 gal. of gas."
Therefore, in my opinion, if your interest in E85 is economic, I suggest you determine if you can purchase 1.56 gal. of E85 for the same price or less than 1 gal. of gas. If you cannot, then you are losing money by using E85 if the article in PM is correct. E85 is not sold in my area so I have no idea what it costs per gallon. How does the cost of a gallon of E85 compare to the cost of a gallon of gas where you live?
Old May 3, 2006 | 03:47 PM
buschman's Avatar
Vehicles that are designed for E85 use different rubber compounds in the fuel system that can withstand the higher water content and corrosivity of E85.
