Wanna Be Cool: Water Pump Swap
Has anyone put a 2003 -2004 Lightning water pump on a NPI 4.6?
I am looking for more flow through out the rpm range, but particularly at slow commuting speed. I am willing to give up performance for cooling.
Any ideas?
The L pump is not even close to being compatable, an informed source tells me. Anybody tried a Cobra pump?
Any ideas?
Neal - Thanx for info.
I have seen your other posts re the Meziere, and it looks like the way to go. But my problem is that I now have four fans running on a 95 amp alternator, which is marginal already. So, I was looking for a better mechanical pump. I guess that a bigger alternator may be inevitable....
HI!... If current flow is the problem then upgrade to a 200AMP police package alternator. You will have to upgrade the ALT wire to a 1 gauge but it works out great. I have 2 16" DERALE electric fans, a 10" tranny cooler fan, and the electric water pump and I still have tons of current. Daily driving with the electric water pump is great. Never had a problem.
Originally Posted by Faster150
damn those are 345 bucks though!
+ after further review - the Meziere pumps 55 gpm - no load....fyi
As I read this thread I am asking why I don't have a problem pulling nearly 12,000 lbs gross combined weight with an 02 4.6 on mechanical fan cooling!
Why do you need all this?
Put in larger capacity radiator. It's size already covers half the front of the truck and the motor is small.
I took the trans cooling out of the large radiator (bypassed) and use two aux coolers.
Originally Posted by Bluegrass
Why do you need all this?.
I hear you. I also hear a lot of others with other make cars and trucks with difficulty down your way.
Something to think about is that the cooling system runs about 200* minus your 115* that's only an 85* spread to keep everything within limits.
The A/C condenser is hot and lessens the radiator ability to cool even more under the narrow temp difference that already exists.
Don't be to supprised that what you do, trying to cool, results in less than expected returns for the effort.
One place you can take about 150* away from the radiator is install a large trans cooler or one in addition to what you might have and by-pass the radiator altogather.
Aiflow in traffic to cool the A/C condenser with the engine speed at idle or low, is a tough deal with out extra help and the power problems it can cause.
Good luck.
Good luck.
Originally Posted by ONELOWF
I live in Las Vegas where it gets hot. No, you don't know hot like I know hot....Imagine 115 degrees ( you probably can't) in traffic, thats not moving much, a/c on max, and you're still sweating your noots off. Now, add some boost....
