Access port for fuel pressure guage and NOS HELP!!!
Old May 13, 2006 | 04:17 PM
HNICRB's Avatar
How can I gain access to the fuel system on my 2004 f150 for guage and nitrous install?
Old May 13, 2006 | 06:20 PM
coryrhonda's Avatar
there is easly at the fuel line connections with the proper O.E. style fittings. why would you want to put the nitrous into the fuel system, I've always installed it into the air induction system.
Old May 13, 2006 | 11:01 PM
dwsf150's Avatar
He needs a fuel supply for the nitrous/fuel injector so the engine doesn't run lean and melt down. Some kits use this setup.
Old May 14, 2006 | 01:49 AM
lees99f150's Avatar
you can buy an adapter to thread on to the schrader test valve. when i did this on my stang i removed the core to allow better flow, but you wont really need to on your truck.
summit has them.
http://store.summitracing.com/partde...5&autoview=sku
Instructions with pic... you will need to use an adapter to connect the N2O fuel line to the adapter.
http://static.summitracing.com/globa...71%282%291.pdf
here is a great place for N2O stuff at a great price. i have the bottle warmer and it is the best i found.
http://www.dynotunenitrous.com/store...ts/default.asp
Old May 14, 2006 | 12:56 PM
HNICRB's Avatar
No, I know all about the schrader access port on the older style FI Fords, but the ,04 F150 has a returnless fuel system, which has NO access port for checking or bleeding fuel pressure. I know someone has installed a wet NO2 kit on a newer gen f150, I just really need to know how I can 'T' into the fuel system. Any help or company where I can buy the required parts would really help!!
Old May 14, 2006 | 05:11 PM
lees99f150's Avatar
I'm not sure about an 04 f150 then.
this is for the new stangs. will this work?
http://www.dynotunenitrous.com/store...?idproduct=204
Old May 14, 2006 | 05:14 PM
Quintin's Avatar
OTC sells an adapter that tees into the fuel line at the rail for checking fuel pressure.
Old May 14, 2006 | 09:40 PM
HNICRB's Avatar
I have an '05 GT and I have this part on my car for a press. guage formy procharger and it is the exact shpae, but the inlet and the outlet are too big. Thanks for your help.
Old May 14, 2006 | 09:41 PM
HNICRB's Avatar
Boy, thats great, do you have a # or website, I've never heard of this company before. Any help would be great!!!
Old May 14, 2006 | 09:47 PM
Quintin's Avatar
The tool number is 310-122; OTC is a manufacturer of OEM speciality tools, any retailer that sells OTC stuff should be able to order it for you. There's this thread in the '04-'06 forum showing what someone else did to tap a fuel pressure gauge in, although honestly that method makes me a little nervous.
