Engine rattle when towing uphill
Old Apr 30, 2006 | 07:46 AM
jparker's Avatar
I have a 96 F150 V8 that I am using to pull a ultralight 25ft. 3000lb camper. Everything seems fine except when pulling uphill or a grade I have a good amount of what seems to be valve rattle or some sort of other rattling noise in my engine. No temp problems. I am burning 87 octane. Any ideas on what noise is and how to reduce it?
Old Apr 30, 2006 | 09:06 AM
projectSHO89's Avatar
This is one of the few times I'd suggest higher octane fuel.
Sounds like ping/knock under load. The higher octane will likely help.
I used to do this when towing my boat with my old 93 Exploder. The high octane when towing was helpful in my case.
Steve
Old Apr 30, 2006 | 11:12 AM
Newt's Avatar
Try running some Techron or SeaFoam through it.
Old Apr 30, 2006 | 11:27 AM
coryrhonda's Avatar
check base timing, and if possible the knock sensor circuit. It was designed to run without spark knock on 87 but sometimes it is just easyer to run a higher octane of fuel.
Old Apr 30, 2006 | 01:06 PM
chester8420's Avatar
Check your timing. Other than that, 89 octane will probably help a lot.
Higher octanes burn slower, so it helps give the piston some time to get over TDC in your case.....
Old Apr 30, 2006 | 02:44 PM
Frmboybuck's Avatar
Id say its ping also....Go to 89 ethanol....Its cheaper than 87 and will most likely solve your problem.
Old Apr 30, 2006 | 08:22 PM
MJN's Avatar
MJN
Registered User
I had a similar rattle in my 99 Explorer. Under moderate acceleration or when going up grade I would get a rattle. The only thing on mne was there was a TSB on a timming chain tension bracket that would fix it on my 4.0 engine but I was over the millage to do it for free. Had over 100,000 when I traded it and still ran great.
