View Full Version : Engine
  1. 4.6 Performance Problems (long)
  2. Due For a Tune-Up
  3. Anyone put their engine on a fuel injection cleaning machine?
  4. Performance Upgrades (Mike Troyer)
  5. FRAM "SureDrain"???
  6. finally received a code
  7. Rotella 5-40
  8. Oil lines going to the filter
  9. Po455 & Po302
  10. Important.....Time to get together about plug blowouts!!!!!!!!!!!!!!!!
  11. Air Intake Sound?
  12. 5.4 Stripped Spark Plug hole
  13. Broken Injector Connector
  14. Oil recommendations
  15. Chirping
  16. Bypassing the DPFE sensor
  17. F-150's Engine and Power compared to other trucks in price range
  18. Rattling sound
  19. oil Filter relocation
  20. Plow truck
  21. Good Spark Plugs and Wires?!?! Your Opinions?!?!
  22. Dealership Oil Changes
  23. 5.4 Intake Manifold on 4.6l
  24. FoMoCo Engine Oil
  25. 4.2 L 1999
  26. First Oil Change...
  27. Thinking of buying F150, need advice on engine issues!!!!!!!!!!!
  28. No start after shut off/ then restarted
  29. 2001 5.4L rotating assembly
  30. Water temp gauge (temp probe installation spot)
  31. Motor Oil and Filter?
  32. New Amsoil air filters?
  33. seprntine belt routing diagram???
  34. Natural Gas Conversion
  35. Infrared Thermography
  36. Rough Idle and gas tank humming
  37. Hesitation at 65-70 mph
  38. Got any pics of painted plastic pieces underhood?
  39. maybe we should have got a f-150
  40. Ok I give up!!!!
  41. broken bolt holding in EGR valve
  42. help with vibration damper
  43. More "blah blah blah"
  44. Replaced IAC....still doesn't idle right.....
  45. Bucking at 1500 RPM
  46. Noise
  47. Mike T underdrive pulleys
  48. Sorry here is the link
  49. Found this on E-Bay
  50. power pulleys
  51. How do I set the ign timing on my '92 F150 5.0L?
  52. 4.6l Iac $123.86????
  53. changing plug?
  54. ALTERNATOR Squealing
  55. what to expect as it ages
  56. Is it bad to drive to the shop with bad coil?
  57. Engine Oil Temperature During City Driving
  58. 5.4L coil pack
  59. 98 f150 5.4L 2v to 4v
  60. ABS Light is on
  61. exhuast smoke
  62. Mobil 1 question
  63. Triton 4.6l 2v to 4v conversion
  64. CRC Fuel Injection Air-Intake Cleaner
  65. k&n vs. kool blue?
  66. In the market
  67. Air Force One Intake Question
  68. Almost embarrassed to ask this
  69. Check Engine Soon Message
  70. Looking for Local Georgia Members.
  71. Track Times
  72. anyone know how to clean an iac?
  73. K&N FIPK OK for Off Roading
  74. Just want to ask a question
  75. Will T-bird headers fit?
  76. Starting Problems
  77. Why is my truck hesitating?
  78. 2003 F150 4.6 auto upgrade questions
  79. Rattling sound at idle?
  80. How to make custom intake
  81. Service Manuals
  82. Hearing a noise and don't know what it is
  83. Need help, wife's GM won't start
  84. Electric Fan
  85. Carbon in intake
  86. '02 SuperCrew - jerky gear shift
  87. 5.4L triton ignition coil problem
  88. Gasoline
  89. Intermittant Wiper Prob.
  90. 4V Heads & 351W
  91. Engine
  92. Cost of repairs
  93. antiseize
  94. Dumb question
  95. 4.6L runs good but won't idle..
  96. winter oil(dino) and cold starts
  97. 1991 F150 knock & ping & SMOKE
  98. Oil
  99. 4.6 to 5.4 or New heads?
  100. 20000 miles without an oil change!
  101. 5.4 P0401 EGR repair
  102. Piston Slap on 2003 5.4
  103. best gas milage ive ever gotten---->
  104. hesitation while accelerating
  105. Broken Bolt / Header leak
  106. I Finally Got "head"!!!!!!
  107. battery light comes on and goes off
  108. Cold Engine Startup Noise
  109. tune-up question
  110. K&N Filter Question
  111. Oil Filter Part Number Difference - Are these the same?
  112. Startup Engine Knock - PS or SP problem?
  113. carb troubles
  114. Aftermarket air intakes for V10s...
  115. Suggestions for buying a 99 4.6 4x4 or an 00 5.4 2wd?
  116. Oil in Crankcase Filter
  117. 5.4L Small Block
  118. Whistle from intake?
  119. 4.6 Runs Rough
  120. EGR Cleaning
  121. Time to change plugs, Questions for you.
  122. replacing various sensors, valves, etc
  123. Spark plug torque
  124. Come on guys
  125. Got some Burnouts?
  126. valvoline maxlife
  127. 98 4.6 Won't Hold Idle
  128. Replacing PCV valve
  129. Fuel Mileage Question
  130. alternator
  131. Thanks guys
  132. Dyno'd Intake?
  133. Motor vibration, and hesitation...bad coils?
  134. MAF sensor location
  135. acceleration ?
  136. F-150 '04 Alert!
  137. sport 4x4
  138. Supercharged V-8 -VS- V-10 power???
  139. listen to this??? truth or myth
  140. 4.6 Pinging
  141. Rattling during Acceleration
  142. Coolant Question
  143. Question for those using Ford Racing wires. . .
  144. Cleaning IAC
  145. kinda interesting
  146. running hot under a load?
  147. Computer chips???????
  148. Electric fans... more questions???
  149. Motorcraft spark plug wire info please...
  150. Poll: RPM in park and in Drive?
  151. Super Unleaded??
  152. Rods
  153. 32v conversion on 4.6
  154. 96 EFI inline 6 -- suggestions please
  155. Rough idle
  156. Flushing engine?
  157. coil pack info needed
  158. 93 F-150 will not start - need troubleshooting advice
  159. 92 Inline 6 fuel pump acting up
  160. Change Oil Pan
  161. Timing chain photo's
  162. Rough idle in drive
  163. plugs ?
  164. Help!! Blue smoke from my 01'
  165. Pic....
  166. SOHC-DOHC conversion
  167. Cleaned my IAC valve
  168. i have a problem
  169. Gold Coolant
  170. Air Intake Kit
  171. fuel smell form engine area.
  172. Pinging issues
  173. timing
  174. 4.6 questions
  175. Dont sweat the Hemi, as far as torque goes..
  176. Fuel Pump and Sending Unit
  177. 89 F150 - Is this the IAC?
  178. thanks
  179. Where's the IAC?????
  180. Help Engine Code - P01450
  181. 4.6 V8 help
  182. 1988 bronco wont start and nothing works lights
  183. Diesel Fuel economy
  184. fiche
  185. anyone know anything about timing on a 1987 mazda b2000??
  186. first and last ford
  187. oil in upper plenum
  188. '92 F-150 5.0 fuel psi reg Q:
  189. dual filter intake
  190. Throttle Body Spacers - Performance Product or "Snake Oil"?
  191. 5.0 engine swap
  192. will it run with injectors???
  193. Friend's 88/89 F150 4.9 starting problems
  194. pulleys/dim lights
  195. '03 Mountaineer 4.6 Got PROBLEM??
  196. electric fans ... power/$$$
  197. odometer
  198. 2001 Lightning Engine Knock
  199. Stock Cobra Supercharger on my truck?
  200. New Engine feels tight
  201. Bypassing the AC pump...what do I have to do.
  202. 93 5.0
  203. More Power for my 4.6
  204. Fuel Selector Valve
  205. Interchanging throttle body & injectors
  206. Engine will not crank when hot on 1998 F-150 4.6L
  207. rough idle
  208. Factory Download
  209. Idle sucks HELP!!!
  210. Holes drilled around air filter intake box?
  211. ATI Procharger For the 5.4 Triton
  212. Runaway throttle, Over rev 01 SCrew
  213. 4.9L Missing
  214. power steering killing engine
  215. 1762 undocumented code
  216. Need a 5.4L engine!!!!
  217. used f150
  218. Intake leak?
  219. which cylinder is #4?
  220. Running nitrous in the expedition this week how big of a shot is safe?
  221. Will those of you with "real" oil pressure gauges
  222. closed cooling system
  223. Check This Mpg Out!!!!!!!!!
  224. 2003 4.6L oil change
  225. CV boot torn and leaking
  226. oil pressure drop?
  227. Bad Fuel Mileage 4.9
  228. Oil pressure gauge install
  229. CODES P1400, P1401, P0401 or P0402
  230. Power Steering Whine 2003
  231. 4.6 Gase Mileage
  232. Torque curves
  233. Clattering
  234. 5.4L Performance Buildup
  235. Service Engine light....confused?
  236. Pulleys.......which ones
  237. Serpantine Belt
  238. Noisy FIPK !
  239. K & N on an '03 S-Crew
  240. Temp gauge is pegged
  241. 5.4L Check Engine
  242. engine cleaning
  243. lightning engine
  244. Check your IAT Sensor Orientation
  245. Miss/backfire on startup, then goes away. Help!
  246. Throttle cable snapped??
  247. Want to make 94 f-150 FASTER
  248. 5.4L Idle problem
  249. Plugs/Wires/Coil Installation in DFW
  250. 4.6 stroker?
