motor question
Old Nov 1, 2006 | 08:19 PM
ford98's Avatar
motor question
I have a 4.6L Vin W (romeo) motor and was wondering if a 4.6L windsor motor would be a direct bolt in. thanks!
Old Nov 1, 2006 | 11:17 PM
4X4ALLTHEWAY's Avatar
Yes. What are the years for both and type of vehicle? I need a little more info to tell you what else you might need as far as accessories.
Old Nov 1, 2006 | 11:31 PM
ford98's Avatar
The 4.6 romeo is out of a 98 f150 4x4 and the windsor motor is a replcement rebuilt motor that says it is for a 97-98 fseries.
Old Dec 13, 2006 | 10:44 PM
If it is for a truck then the pulleys should all be the same. You may want to check the tensioner to see if there is any differenc there. Every thing else should bolt up. Hope you have the flywheel for both engines and good luck.
