EVAP canister purge solenoid
I've been battling a problem with my 92 F-150 4x4 302ci. Idle is very eratic, will not upshift properly, dies when approaching a stop sign, etc. I have replace the Idle Air Control valve, reset the computer and it's no better. While troubleshooting last night, I disconnected the IAC valve and the EVAP purge solenoid. The thing idled perfect, I installed the IAC valve and left the purge solenoid off and it's fine. I hooked up the vacuum line from the purge canister directly to the Throttle body vacuum port, (where the purge solenoid was) I left the air cleaner assemble off, but drove the truck and it drove great, other than a firmer than normal shift. Could a bad Purge Solenoid have been causing my above problems? That is the conclusion that I have come to, but it doesn't make sense after I researched what the EVAP system does.
Any thoughts????
Thanks,
Jon
Any thoughts????
Thanks,
Jon
