Oil Pressure Light
Old Nov 10, 2006 | 07:16 AM
AdamO's Avatar
Oil Pressure Light
Hi Guys,
I have a 2002 F150 w/4.6. Yesterday while riding home my oil pressure guage went to zero and the oil light came on. I stopped and checked all my fluids and everything was fine. I re started and everything was fine. Today, the guage went to zero a couple of times, but immediately came right back up. Is this a sensor problem, or do I have a serious problem?
Old Nov 10, 2006 | 07:26 AM
projectSHO89's Avatar
Oil sending switch. A common failure.
Steve
Old Nov 10, 2006 | 08:20 AM
AdamO's Avatar
Where is the oil sending switch located on my 2002 F150 w/4.6? I'd like to change this myself if it's not a difficult fix.
Old Nov 10, 2006 | 09:38 AM
Ash575's Avatar
Could be an oil pump going out..???
Old Nov 10, 2006 | 12:24 PM
Bluegrass's Avatar
Located behind the oil filter on it's adapter.
It has a locking connector.
Hard to get at.
Move it around a bit to see if it is just a dirty connection. If not then it needs changing. All it is is a switch that closes at about 6 psi. The dash gauge in not telling you anything but that the switch did or did not close.
Old Nov 10, 2006 | 04:19 PM
ajscarfo's Avatar
Steve
CHECK THE OIL PUMP!! this happend to me then all of a sudden went out and blew the motor i just put a new motor in my 02 !! get it checked its no joke!!
Old Nov 10, 2006 | 09:08 PM
Hundreds of oil pressure switches will fail for every pump that fails.
If in doubt, connect a guage.
Steve
Old Nov 11, 2006 | 02:59 AM
masseyman's Avatar
oil filter?
Something to keep in the back of you mind is the oil filter has plugged or failed. I had this happen once on an old Ford car(1967). Before everybody jumps in and says the oil filter has a bypass valve. How failsafe can a 3 or 4 dollar oil filter be?
Old Nov 11, 2006 | 02:34 PM
ajscarfo's Avatar
Steve
ya thats great great info unles your thr one with a pump failure, look around the site here to see what a ENGINE replacment runs!
Old Nov 12, 2006 | 02:26 AM
Duffman0286's Avatar
this is where troubleshooting comes in handly you do the basic first then work your way up mechianics do the same of couse as u did check fuilds, then do a oil change/filter , ok then considure a senser failure and replace if still bad look into oil pump no reason to go out a buy a oil pump when it could be something simple
Old Nov 13, 2006 | 08:26 AM
ajscarfo's Avatar
actually i dont think a mechanic would buy and replace a sensor they would hook up what im sure they have as some kind of mechanical guage to see actual pressure before they just sold you a sensor!
any updat on the oil pressure situation?
Old Nov 13, 2006 | 08:43 AM
Wanna bet? A mechanic will throw a new sender on there first since it takes the same amount of time to replace as it does to attach a guage. If the light goes off when the sender is replaced, he's done.
For the mechanic, it's not about doing it right, it's about getting it done in the least possible time.
Steve
Old Nov 13, 2006 | 08:37 PM
ajscarfo's Avatar
Steve
yea ill bet i had it done on the companys 3 e-150 vans all had cloged pickups ( they where bought at auction! and if thats how your mechanic works then he sucks and theat would be the reason ford is losing market share i belive the service at the dealer is a big impact on peoples satisfaction and return sales!
oh and the dealer i took it to was phofenbaugh ford here in saint cloud florida!
