View Full Version : Engine
  1. Ignition ?
  2. aftermarket coils vs. chip and/or?
  3. 2002 F150 is jumpy at idle, new-b needs info! and help!
  4. Where is the engine id tag (mid 70s 390)
  5. 01 4.6L engine seized. will 05 fit???
  6. PCV Valve
  7. Engine Swaps
  8. New Owner 94 5.0 4x4 Needing advice on parts and how to's
  9. 2006 5.4L Intake System
  10. 2002 Mountaineer (Explorer) 4.6 NO START won't even try
  11. Throttle Issue
  12. Cps
  13. First Time Towing With 97 4.6
  14. Cold oil Change?
  15. serious ilde help?
  16. Studdering" Problem at constant speed, Need ideas on fix Please
  17. miss firing problems
  18. 4.9l Inline 6 spark plug problem
  19. 1998 5.4 F-150 Spark Plug Locations
  20. Edge Evo over the XCT2?
  21. Need advise on an engine that overheated-should I get rid of it?
  22. pinging on the 3v 5.4
  23. Misfire in 5.0
  24. 4.6 triton
  25. 4.9 L engine
  26. egr puzzle
  27. need help, 91 ford f-150 ext cab engine dies in gear
  28. 01 5.4 slow off the line.
  29. 00 f150 colum swap out, PATS problem, fuel pump problem
  30. Engine will not start unless accelerator is pushed down!
  31. Do I need a new engine???
  32. Diesel F150???
  33. Burning Smell and Loud Noise
  34. Have I damaged my engine????
  35. 5.4 w/ misfire
  36. Remanufactured engines
  37. 2000 f150 4.6 runnig bad help!!!
  38. Stalling in 3rd and 4th!!
  39. No heat from the heater
  40. Injector coils on Ebay
  41. :confused: 1997 Ford F-150 4.6L (Blown head gasket)
  42. got the ac to work
  43. change ac clutch ac still wont work
  44. What are the HP and ft/lbs numbers for a '97 4.6L
  45. Dealership Oil Change Question
  46. Location of PCV valve in 92 5.0 V8 model
  47. Stuck lifter or noisy tappet?
  48. 97 4.6 acting up
  49. Intermittent death when warm
  50. 1988 idle problem
  51. need compression on a 1988 lariat xlt
  52. Its Alive!!!
  53. Does anyone have any experience with nitrous oxide on an F150 (4.6L)
  54. Won't start. Insrt pnl no power. Anti theft?
  55. Removing oil pan in '92 F-150 5.0 V8
  56. dead 4.6
  57. Tune up?
  58. k&n oil filter
  59. More "excessive EGR flow" problems
  60. Leaky Oil Filter-Why???
  61. changing idle speed
  62. Quick: I need help tonight.
  63. put the 97 150 on road today
  64. Gasoline in engine oil?
  65. 04' SuperCrew 5.4 Blowing Oil
  66. Upgrading injectors, which to get and what to do?
  67. "tornado"
  68. Fuel Problem?
  69. '94 6cyl 5spd MPG
  70. Throttle position sensor.
  71. 2001 SuperCrew 4.6 Smoking on Start Up
  72. Additional info on my A/C problem
  73. I want more torque
  74. Fluid Leak under truck
  75. 1999 5.4 sounds like a diesel
  76. Throttle body problem?
  77. Asking if it is worth it????
  78. Thank you to all....
  79. A/C problems:'(
  80. 5.4 3V EFI vs. 5.4 3V EFI FFV engine
  81. Oil Filter stuck, so I left the old one on it?
  82. Oil problems...Help?
  83. Fuel Additives
  84. 4.6 to 5.4?
  85. Check engine light
  86. Stumped by vibration
  87. Access port for fuel pressure guage and NOS HELP!!!
  88. Dyno
  89. Spark Plug Question
  90. E-fan??????
  91. Geezzz, Now mine won't start..
  92. Engine Chirp - Spark Plugs??
  93. 5.4 Flex Fuel Motor
  94. Won't Start...help!!!!!
  95. ???Condensator???
  96. Misfire/backfire on heavy acceleration
  97. help with fuel problem please
  98. Hypertech Power Programmer III & The Jet
  99. Pulling Codes
  100. Cold air, Spacer, and exhaust
  101. Need advise on bigger engines for 1998 F-150
  102. Amazing
  103. fully functional ram air hood and the rouschcharger
  104. E85
  105. Po232 Code
  106. Ford Lightning SVT 5.4 litre motor /Engine
  107. Engine Suddenly Shuts OFF!!!!
  108. Synthetic oil
  109. Need Help
  110. Humming Noise
  111. Building a 4.6 ????
  112. PO133 and P1131 - Double checking after searching
  113. ignition woes solved!!!
  114. ac wont work
  115. Too Much Oil
  116. Code p0354
  117. truck started running rough
  118. DINO oil vs SYNTHETIC
  119. Running Rough and Gas Mileage
  120. Air release when gas cap is removed.
  121. lost keys!
  122. Idles high when hot.
  123. 5w20 oil crucial?
  124. No fuel pressure??
  125. WOW!! Look what I found in my intake!!
  126. Going Crazy
  127. K&N air filter/intake kit on the 4.2
  128. Hard acceleration skip on 01, 4.6 Supercrew
  129. Ethanol F150 ?
  130. Need Help!
  131. question about labor costs?
  132. Fuel Line 0-Ring Help
  133. Dealer "Motor-Vac Service" yes or no?
  134. what is the best way to break in new motor
  135. Lightning swap
  136. What ya think of my truck?
  137. Ac compressor turning on and off.
  138. cams
  139. 04 5.4 Burning oil??
  140. Check engine and abs lights will not go out!
  141. Will a v10 fit my F150? PART 2
  142. 4.6 misfire
  143. Firing order
  144. Washed engine - Won't Start
  145. 06 5.4L To Replace a 98 5.4L Motor
  146. The 98 5.4L - Improving the power
  147. non oxy
  148. more power
  149. motor is in 4.2
  150. OBD Codes- what they are, what they mean
  151. help
  152. eco fuel system
  153. diesel v6 in f150
  154. Knocking Motor
  155. rebuilding 4.2
  156. K&N intake system
  157. Check Engine Codes: PO171+PO174 System Bank? What do they mean?
  158. Vacuum Resevior
  159. cheap hp upgrades?
  160. Help
  161. 2004 F150 FFV conversion
  162. CEL light on and misfires.
  163. U-bolt problem......
  164. Starting question. 4.6L
  165. naturally asperated power
  166. engine idle fluctuates when in park.
  167. Next mod??
  168. ticking noise in 2000 f-150
  169. 4.6 1/4 mile times...
  170. Weird question hopefully someone can help...
  171. 1990 4.9L Straight Six (Missing Head Gasket)
  172. 4.2 L V-6 exploded drawings
  173. E-85
  174. Supercharger QUESTION ??????
  175. Hesitation an Chugging
  176. 2005 5.4 has ticking noise
  177. Replaced COP. 2wks later same problem
  178. Gettin the gas out.
  179. 2nd COP in 2 days
  180. Comparing...
  181. Air Pressure Release from Gas Cap
  182. Just traded my 5.0 in for a F150
  183. Rev limiter on 4.6 Triton?
  184. 2003 5.4 Knock Sensor
  185. Engine running rough
  186. 91 V8 5.0 Shaking after acceleration... HELP
  187. 1997 F150 4.2L V6 Engine Swap Question
  188. help with computer?????????
  189. K.N air filter good/bad
  190. Fixed Broken Studs
  191. What is the firing order of a 95 ford f150 302?
  192. weight of 04-07 F150
  193. 350 flywheel horsepower 5.4
  194. One or Two O2 Sensors?
  195. 4.6L Supercharger?
  196. Check Engine Light on then off
  197. freeze plugs
  198. Nitrous on my work truck??
  199. Problematic OEM Dual Fuel Systems
  200. '97 4.6L runs rough and won't idle in gear
  201. Bigger Throttle Body Good Or Bad?
  202. Oxygen Sensors
  203. timeming chains o4 5.43v
  204. P0405 after P0401?? Any Suggestions
  205. 06 F150 wont start after visit to the trailer dealership!
  206. Problems and i dont know what
  207. Engine rattle when towing uphill
  208. Does anyone know the differences in the 4.2L between '97 and '03?
  209. 3 valve cylinder heads
  210. Check engine light after spark plug change
  211. Bad mass flow or vacuum leak?
  212. Fuel cut above 1/3 throttle.
  213. seafoam from HE//
  214. Best Method to Wash Engine?
  215. Fuel tank shuffle !!!
  216. will my 2002 f-150 run E-85?
  217. Would this coil pack fit?
  218. Need more grunt to tow trailer!!!
  219. Please Share Your Expertise - Significant Lurching on Acceleration(??)
  220. truck quit and wont start
  221. What's the best way to thin/dilute mineral oil?
  222. Methanol Injection
  223. Need my EGR?
  224. cooler air intake?? Thoughts!
  225. Low Idle RPM'S
  226. Time to do head gasket...
  227. I'm Impressed!!!
  228. engine missfiring
  229. Taller gear help mileage?
  230. F150 2000 correct motor oil info request
  231. HyperTech Pwr Programmer
  232. Confused
  233. Custom Twin Turbo Ford Gt!
  234. Best upgrades for 2006 4.6
  235. Which Oxygen Sensors
  236. does anyone know if a ford dealer can reprogramm your ecu
  237. Stock air filter.....
  238. HELP! Replaced IAC and EGR and still dosen't run right
  239. Washed my engine, now i'm in trouble, help!
  240. Battery Dummy Light Appears When Shifting
  241. 1995 engine choices for f150...???
  242. Please help me decide...
  243. 427 Sohc
  244. No Smoke After Seafoam!!!!!
  245. Bad EGR???
  246. What's Your Average MPG?
  247. New truck.. blown motor... Give me swap ideas
  248. Cobra Blower on an F150?
  249. Troyer Performance
  250. automatic tran fuild would do the same thing as sea foam
