Problem
Problem
I was just getting home and while i was in my neighborhood and i was turning and my pwer steering went out and then my truck shut off and it said low oil pressure but i just checked the oil and it was fine , has anyone had this happen to them before? or know what could be wrong.thanks
on
The idle may have gotten so low that the PS was not producing enough pressure to assist then it got so low that the truck stalled. How did you get the truck home? Does it run today? Your truck may have simply stalled. One of your accessories may have seized causing the stall? The Iac may have allowed too low an idle and it stalled.
ok thanks guys and it hasnt happened again in the last 2 days but this happened and there is like a pinging nose like a bad bearing or something when i get my rpms up and this all happened after i put my edge programmer on dont no if that has anything to do with it but i have been running it on performance the whole time.
