Help?Advice? Engine Swap
Old Jan 6, 2009 | 06:18 PM
pu2ded0's Avatar
Looks my '97 5.4 has bitten the dust at 116K. Need any advice i can get on engines that I can replace it with. Wanna stay with the 5.4. If anyone can help me with models and changes necessary to put later engines in my truck i would be much obliged.
Old Jan 6, 2009 | 06:28 PM
wackojacko's Avatar
Lightning engine swap!!!!
Old Jan 6, 2009 | 06:35 PM
Matts ford's Avatar
any 5.4 2v will bolt right in. a 97 and 98 will be a direct swap with no changes needed what so ever. if you go with a 99-03 then you will need to get the pcm tuned because of the PI heads.
pu2ded0's Avatar
ain't got that kinda bank. would rather keep it simple.
Old Jan 6, 2009 | 06:37 PM
pu2ded0's Avatar
Can you elaborate Matt? I really wanna find a later model. It appears that most '97 and '98's have high mileage/
Old Jan 6, 2009 | 06:52 PM
Matts ford's Avatar
i'd look in the junk yards (expedition/f150/some navigators/e series vans). i'm sure you'll find a low mileage 5.4 2v there. and if the vehicle is a 99+ 5.4 2v then you can pull the pcm and harness that way no special tuning is needed. what kind of price range were you looking at?
Old Jan 6, 2009 | 06:53 PM
wackojacko's Avatar
What happened with the engine that is currently in the truck? Your cheapest route may be to rebuild/repair current engine or get a remanufactured 97/98. Are you looking for more power? Reliability? What is your goal?
Old Jan 6, 2009 | 06:54 PM
jbrew's Avatar
I don't think you have to tune that swap Matt - Your only +25 hp/+15 trq - It will work without a tune AFAIK. Now you can dial it in better on the dyno, but I don't believe it's required.
If this isn't accurate, please post up.
Old Jan 6, 2009 | 06:55 PM
jbrew's Avatar
Uhmm? Not
Don't fall for this one.
Old Jan 6, 2009 | 06:58 PM
wackojacko's Avatar
Originally Posted by jbrew
Uhmm? Not
Not what?
Matts ford's Avatar
oh alright then. that makes it even easier
Old Jan 6, 2009 | 07:12 PM
jbrew's Avatar
Yea, I pretty sure all he has to do is tap the cross-over to incorporate his ECT sensor,- if he goes 99+.
Old Jan 6, 2009 | 07:24 PM
wackojacko's Avatar
Sorry! I found your old thread and answered my own question.
Old Jan 6, 2009 | 07:25 PM
pu2ded0's Avatar
The engine may be shot. A top end rebuild alone is over $1200. Been searching car-part.com for an engine. Looking into buying a whole salvage vehicle for the swap, something hit other than front. Need to be really sure of the difficulty. If i buy a whole truck, i can swap the disc rearend into my "97. That's one good thing that could come out of this. Trying to find a silver lining....lol
Old Jan 6, 2009 | 07:50 PM
wackojacko's Avatar
http://www.greenleafauto.com/part_search.aspx
I have used this company many times in the past. They had great customer service and they actually stand behind their warranty.
