Draining coolant from the block
Old Dec 30, 2008 | 10:53 AM
Sphinx's Avatar
'99 5.4L, So, I want to flush out the old coolant and put some clean stuff in there. I saw the online writeup about draining the coolant from the block and it seems like coolant will end up going everywhere and making a mess if I just take the drain plug off. Is there a recommended way of doing this without necessitating removing a bunch of crap?
Old Dec 30, 2008 | 11:31 AM
tjk_in_cny's Avatar
If I remember right when I did mine last summer. There is a extension off of the radiator drain plug for a rubber hose. I know that I didn't have any mess when I did mine. I didn't have to remove anything to get to my drain spout either.
Old Dec 30, 2008 | 01:15 PM
Sphinx's Avatar
I figured that part out. I'm talking about draining the actual block itself. According to the Haynes book, there's a drain plug on each side of the block too.
Old Dec 30, 2008 | 07:11 PM
tjk_in_cny's Avatar
hmm, I'll have to look at my manuals. Your not refering to the freeze plugs are you.
Old Dec 31, 2008 | 01:40 AM
defconfive's Avatar
Registered User
I would compare it to changing your oil. Once you remove the plug, fluid will pour out.
When I drained the my 99 4.6 block, I put a pail underneath so the coolant would not go all over the driveway.
Old Dec 31, 2008 | 04:08 AM
KEITHHATTER's Avatar
I have never drained the block. For the time and trouble that it is to do, I just pay for a flush and be done with it. I believe last year it cost me 75$ and 1 hour out of my day to do it.
Old Dec 31, 2008 | 05:42 AM
jbrew's Avatar
Damn, I would do it for $50 - Simple, takes no time to speak of once you know what your doin.
I did a write up on that, - if you find it, let me know would yuh.
There's a inset (female) allen bolt (T55 I believe)/drivers side. If you have a drain plug on the passenger side , consider yourself lucky because I never seen one on that side and I've looked on a few different trucks.
You'll need impact action to get her out or you'll most likely strip it. Tape it before you install.
Good Luck
Old Jan 1, 2009 | 04:10 AM
jbrew's Avatar
Hey, I found the right up from Ford Service. Need and email address to send it to. Covers everything - Burping/Bleeding as well. To much work to post here, emails easy tho.
Old Jan 1, 2009 | 09:42 AM
lzrj's Avatar
I wondered why I did not get nearly enough coolant out that I thought I would get when I did a first change about two years ago.
I decided last year that I would just drain what I can from the radiator valve and just refill that once a year. Its very simple and quick to do (other than waiting for it to drain but I usually tinker with other things while Im waiting). After several years, its almost like getting a complete change and always keeps fresh coolant in there.
Old Jan 1, 2009 | 04:18 PM
BlueOvalFitter's Avatar
Cool
On my 97 F150 I removed both plugs from the block,one on each side,and installed a 1/4" brass nipple with a ball valve to drain the block!
Old Jan 1, 2009 | 05:19 PM
str8t six's Avatar
coolant will go everywhere!!! i took mine out of the drivers side and used a funnel and a some hose to direct the coolant. but it was a huge pain the butt!!
Old Jan 1, 2009 | 05:25 PM
jbrew's Avatar
You lucked out having two plugs, mine absolutely does not! I went as far as wire wheeling the entire passenger side of the block. No Plug
Same deal on a 99 I work on once in awhile, except for the wire wheeling part (*** that, not doing that again).. I haven't check the 01 yet. What's the deal, why just one on some?
Ball valves a good idea - that's where it gets messy -Coolant hits to many obstacles on the way down before making it to the bucket. Yea that would be nifty, connect a piece of tube to the valve right ?
You have a lock on that valve? That would suck if you hit a chuck hole hard and she turned on
-What about debris/foreign matter flying into the valve, turning it ? -or possibly taking it out completely
Hope your not paranoid now .
