oil pan pet****?
Old Jan 3, 2009 | 01:58 AM
str8t six's Avatar
oil pan pet****?
Does anyone make of these or something similar?
my RCD lift crossmember goes right under the oil pan drain and it is a PITA to get a funnel up next the drain and let out the oil.
Old Jan 3, 2009 | 01:59 AM
str8t six's Avatar
ok, why is petkock blocked??
Old Jan 3, 2009 | 02:00 AM
Shinesintx's Avatar
Because you the site censor is censoring ****... You know, like your wiener...
Old Jan 3, 2009 | 02:08 AM
Faster150's Avatar
then take the lift off.. sounds like a design flaw from RCD
Old Jan 3, 2009 | 03:04 AM
dirtrider596979's Avatar
let the oil hit the crossmeber then wipe it off when your done, lol
Old Jan 3, 2009 | 03:38 AM
Klitch's Avatar
use sheetmetal, my fabtech does the same. the only problem with letting it hit the crossmember is it goes everywhere and makes like 3 or 4 puddles, really pisses ya off when your trying to keep it in the drain pan and not on the floor.
Old Jan 4, 2009 | 07:47 PM
str8t six's Avatar
how did you shape the sheetmetal? like a V-shape or something?
Old Jan 4, 2009 | 09:15 PM
Faster150's Avatar
thats why you use someone else' garage
Old Jan 4, 2009 | 09:30 PM
srfd44's Avatar
www.quickoildrainvalve.com
Get the one with the hose bib
Old Jan 5, 2009 | 03:24 AM
Klitch's Avatar
not really, a slight U shape at the top so i could lay it up on the crossmember and loosen the bolt. made a V shape at the bottom to direct the oil more.
