In line block heater Question?
Old Jan 16, 2009 | 10:59 AM
05_sprcrw's Avatar
I am currently tossing up the idea of putting a 1000watt inline water heat pump style block heater. I have found one for a good price but I was wondering if from the outlet of the heater core goes directly back to the radiator? If anyone has installed one of these how hard are they to install, and are there any problems that have occurred with it installed. Thanks
Old Jan 16, 2009 | 04:42 PM
Okieboy's Avatar
Fairly easy to install. Installed one years ago with no problems. Just make sure you zip tie the harness or wiring very well! good luck
Old Jan 16, 2009 | 08:19 PM
Camarothatcould's Avatar
Has to flow with normal flow of engine operation. Also make sure your system is filled back up n primed before you plug it in or you'll burn it up
Old Jan 16, 2009 | 10:30 PM
jbrew's Avatar
I don't understand the need for these things unless you live in a 40 below climate. Since I purchased this truck in 1998 - It's been the best cold start vehicle I ever owned - Always fires right up. If there's a problem, it lies somewhere else. Sub-zero warm up times are 15 seconds/one cycle - That's how long they take to cycle. And if you have a crank no start problem - Keep in mind the computer shuts the injectors down after 5 seconds of cranking - If it don't start after 5 , it's not going to. - I didn't know that after installing new injectors - Took two days for me to figure that one out
Old Jan 17, 2009 | 02:02 AM
Its not a matter of not starting, well with me it aint. Its a matter of a MUCH faster warm-up time. I plug my truck in just for the simple fact of it warming up 10 times faster than starting a BONE cold motor and then getting on it to warm up quicker. If I had the money for one, I would've put in a circ heater also.
Old Jan 17, 2009 | 03:10 AM
jbrew's Avatar
Oh , okay -Got it
Old Jan 17, 2009 | 09:06 AM
Wouldn't you like to jump in your truck when it's 0 out, start it, and hit the heater and get warm air right away?
Old Jan 17, 2009 | 10:39 AM
jbrew's Avatar
If someone else was paying my electric bill
Old Jan 18, 2009 | 02:12 PM
The extra electric bill should be balanced out by the fuel savings starting a warm engine.
Old Jan 18, 2009 | 02:56 PM
Tumba's Avatar
When your not paying the electric bill anyway, WTH
Old Jan 18, 2009 | 03:04 PM
jbrew's Avatar
That my kids philosophy
Old Jan 18, 2009 | 06:56 PM
Norm's Avatar
Nope, the extra tablespoon of gas is much cheaper than plugging in your truck all night.
Old Jan 18, 2009 | 07:09 PM
05_sprcrw's Avatar
Thanks for all the input you guys. I think I am going to go ahead and get one.
Old Jan 18, 2009 | 07:36 PM
atta boy!
