vaccum noise!
Old Dec 29, 2008 | 09:27 PM
hubuscapus's Avatar
Talking vaccum noise!
Hey guys i was looking around the site and ran across a problem another guy has that i have from time to time and was wondering if anyone had a clue. On my 4.6L supercrew when its cold out and you turn the heater on i get this god awful vaccum noise that sounds like a goose being strangled! the engine idles up and want to lurch forward a bit if your at a stop light. if you give it some gas it goes away. i have also noticed it doing it when i let off the brakes to leave a light it will do it, it seems like if you use any thing that uses vaccum it acts up. any ideas?
Old Dec 30, 2008 | 08:37 AM
bigbronc's Avatar
Is it a "hooting" noise? If so, sounds like the iac valve is fluttering. I assume you have it in defrost mode when turning on the heat which actuates the a/c compressor causing the engine to idle up. This is why it coincides with the heat. Try tapping on the valve when it happens.
Old Jan 5, 2009 | 08:24 PM
Medjai06's Avatar
thx hubuscapus for posting this in here, didnt think about it, but bigbronc is right, it is the IAC valve, I did quite a bit of researching and got the same answer, flippin IAC valve, same noise, same idle jolt...so yea, Im just gonna take mine to the factory, cuz i dont feel like fiddling with it...
