Nagging codes
Old Jan 1, 2009 | 09:17 PM
geerusso's Avatar
Unhappy Nagging codes
2002 F150
4.2V6
65,000 miles
I have been getting the same two codes for the past few months almost as soon as winter started (1131 and 1151) I have:
Checked for vacuum leaks
Replaced air filter
checked oil level
Replaced both upstream O2 sensors
Every time I clear the codes they return within a couple of driving cycles.
Can anyone tell me what the most common cause is for these two codes to appear. As of yet I have not noticed any proplems with performance, just the nagging codes.
Thanks,
Geoff
Any information would be a big help.
Old Jan 2, 2009 | 06:15 PM
Matts ford's Avatar
usually its a vacuum leak. have you checked the intake seals? when they leak, they usually leak when the engine is cold and they expand when it warms up and seal it. are you getting enough fuel pressure? any exhaust leak?
Old Jan 3, 2009 | 10:02 AM
geerusso's Avatar
What is the best way to check the intake seals for a leak?
What is the best way to check for an exhaust leak?
How do I check my fuel pressure?
Old Jan 3, 2009 | 01:55 PM
Matts ford's Avatar
to check the intake seals just spray carb cleaner around the intake.
exhaust leak- generally you should be able to hear it but use something to clog the exhaust. like have someone hold rags at the end of the tailpipe as you listen for a leak. sometimes an exhaust leak can give an o2 sensor a false reading.
to check the fuel pressure you need to hook a fuel pressure tester to the shrader valve on the fuel rail.
